Line Status HEC Error Upstream
- Re: LINE STATUS HEC ERROR UPSTREAM
14-02-2016 9:54 AM
Can you please plusnet or anyone explained why I ve got too much errors(HEC) and why is SNR margin (dB) Upstream (0) ?
My line status 14.2.2016 9:50
Attainable rate (kbit/s) 73796 20212
SNR margin (dB) 18.3 0
Line attenuation (dB) 13.3 7.4
Output power (dBmV) 13.3 7.4
Downstream Upstream Downstream Upstream
Line rate (kbit/s) 74313 19999 0 0
CRC errors 254 127 18 0
FEC errors 0 0 0 0
HEC errors 154 4294967290 32 0
[Moderator's note by Dick (Strat) All caps title edited as per forum rule.
FEC errors 0 0 0 0
Message 1 of 6
(2,444 Views)
5 REPLIES 5
14-02-2016 10:05 AM
Speedtest and ping test looks like good.
Message 2 of 6
(1,965 Views)
14-02-2016 10:50 AM
Sppedtest and ping look good...
What modem/router are them stats from?? some routers have incorrect gui error stats (you will need to telnet in to get the correct figures)
More info on HEC errors here http://www.kitz.co.uk/adsl/linestats_errors.htm
Ian
dick:green URL fixed.
Ian
Message 3 of 6
(1,965 Views)
Re: Line Status HEC Error Upstream
14-02-2016 11:14 AM
Used eche huawei hg-612...Telnet result is :
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 20200 Kbps, Downstream rate = 73568 Kbps
Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 74313 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.3 6.2
Attn(dB): 18.3 0.0
Pwr(dBm): 13.3 7.4
VDSL2 framing
Bearer 0
MSGc: -6 26
B: 243 237
M: 1 1
T: 0 42
R: 10 16
S: 0.1046 0.3781
L: 19435 5374
😧 8 1
I: 254 127
N: 254 254
Q: 8 0
V: 0 0
RxQueue: 60 0
TxQueue: 20 0
G.INP Framing: 18 0
G.INP lookback: 20 0
RRC bits: 0 24
Bearer 1
MSGc: 154 -6
B: 0 0
M: 2 0
T: 2 0
R: 16 0
S: 6.4000 0.0000
L: 40 0
😧 3 0
I: 32 0
N: 32 0
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 1546838
OHFErr: 0 1
RS: 234294200 513991
RSCorr: 27992 7
RSUnCorr: 0 0
Bearer 1
OHF: 382816 0
OHFErr: 0 0
RS: 3827548 0
RSCorr: 0 0
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 4970515 0
rtx_c: 177 0
rtx_uc: 0 0
G.INP Counters
LEFTRS: 3 0
minEFTR: 74313 0
errFreeBits: 6969822 0
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 878701175 0
Data Cells: 16584500 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 1
SES: 0 0
UAS: 20 20
AS: 6140
Bearer 0
INP: 49.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 0.00 3.98
OR: 0.01 64.22
AgR: 74388.78 20063.54
Bearer 1
INP: 4.50 0.00
INPRein: 4.50 0.00
delay: 3 0
PER: 16.06 0.01
OR: 79.68 0.01
AgR: 79.68 0.01
Bitswap: 4981/4981 2/2
Please let me know if is everything correct..thanks
Status: Showtime
Retrain Reason: 0
Mode: VDSL2 Annex B
Trellis: U:ON /D:ON
Down Up
SNR (dB): 6.3 6.2
Attn(dB): 18.3 0.0
Pwr(dBm): 13.3 7.4
VDSL2 framing
Bearer 0
MSGc: -6 26
B: 243 237
M: 1 1
T: 0 42
R: 10 16
S: 0.1046 0.3781
L: 19435 5374
😧 8 1
I: 254 127
N: 254 254
Q: 8 0
V: 0 0
RxQueue: 60 0
TxQueue: 20 0
G.INP Framing: 18 0
RRC bits: 0 24
Bearer 1
MSGc: 154 -6
B: 0 0
M: 2 0
T: 2 0
R: 16 0
S: 6.4000 0.0000
L: 40 0
😧 3 0
I: 32 0
N: 32 0
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 1546838
OHFErr: 0 1
RSCorr: 27992 7
RSUnCorr: 0 0
Bearer 1
OHF: 382816 0
OHFErr: 0 0
RS: 3827548 0
RSCorr: 0 0
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 4970515 0
rtx_c: 177 0
rtx_uc: 0 0
G.INP Counters
LEFTRS: 3 0
minEFTR: 74313 0
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 1
SES: 0 0
UAS: 20 20
AS: 6140
Bearer 0
INP: 49.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 0.00 3.98
OR: 0.01 64.22
Bearer 1
INP: 4.50 0.00
INPRein: 4.50 0.00
delay: 3 0
PER: 16.06 0.01
OR: 79.68 0.01
AgR: 79.68 0.01
Message 4 of 6
(1,965 Views)
14-02-2016 11:49 AM
It's a GUI bug with the unlocked HG612 Modem, mine says the same.
Message 5 of 6
(1,965 Views)
14-02-2016 1:37 PM
Thanks mate...so rest of telnet value are ok?
Message 6 of 6
(1,965 Views)
