Line Stats
k99
Line Stats
Hi, anyone care to comment on my line stats specifically the SNR margin. I thought both of these should be around the 6db mark. I also seem to be synchronized higher than the max rate.
Confused!
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 25114 Kbps, Downstream rate = 62624 Kbps
Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 64146 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.1 15.1
Attn(dB): 16.6 0.0
Pwr(dBm): 13.7 7.1
VDSL2 framing
Bearer 0
MSGc: -6 26
B: 243 237
M: 1 1
T: 0 42
R: 10 16
S: 0.1211 0.3781
L: 16776 5374
😧 8 1
I: 254 127
N: 254 254
Q: 8 0
V: 0 0
RxQueue: 51 0
TxQueue: 17 0
G.INP Framing: 18 0
G.INP lookback: 17 0
RRC bits: 0 24
Bearer 1
MSGc: 154 -6
B: 0 0
M: 2 0
T: 2 0
R: 16 0
S: 6.4000 0.0000
L: 40 0
😧 3 0
I: 32 0
N: 32 0
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 1433041
OHFErr: 0 544
RS: 1339577784 602031
RSCorr: 17005 2354
RSUnCorr: 0 0
Bearer 1
OHF: 43178272 0
OHFErr: 0 0
RS: 431782101 0
RSCorr: 0 0
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 16290 0
rtx_c: 2053 0
rtx_uc: 0 0
G.INP Counters
LEFTRS: 14 0
minEFTR: 64142 0
errFreeBits: 678438693 0
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 3949701053 0
Data Cells: 1285399997 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 410
SES: 0 0
UAS: 27 27
AS: 693554
Bearer 0
INP: 48.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 0.00 3.98
OR: 0.01 64.22
AgR: 64211.28 20063.54
Bearer 1
INP: 4.50 0.00
INPRein: 4.50 0.00
delay: 3 0
PER: 16.06 0.01
OR: 79.68 0.01
AgR: 79.68 0.01
Bitswap: 138850/138850 109/109
Total time = 1 days 39 min 41 sec
FEC: 17005 2354
CRC: 0 544
ES: 0 410
SES: 0 0
UAS: 27 27
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 9 min 41 sec
FEC: 3 2
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 48 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 39 min 41 sec
FEC: 56 5
CRC: 0 1
ES: 0 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 1666 325
CRC: 0 103
ES: 0 73
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 8 days 39 min 13 sec
FEC: 17005 2354
CRC: 0 544
ES: 0 410
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
