Line Speed
- Re: Line Speed
Line Speed
02-06-2015 1:08 PM
Could anybody explain the meaning of these figures as I am somewhat confused by the difference between these speeds and my actual speed.
Thanks.
Re: Line Speed
02-06-2015 1:22 PM
Re: Line Speed
02-06-2015 1:25 PM
Re: Line Speed
02-06-2015 1:28 PM
Re: Line Speed
02-06-2015 1:36 PM
Re: Line Speed
02-06-2015 2:12 PM
Re: Line Speed
02-06-2015 2:15 PM
This will need a staff check
Re: Line Speed
02-06-2015 2:21 PM
Re: Line Speed
02-06-2015 2:23 PM
The Plusnet Current Line Speed should be the same as the IP profile and isn't so something is very badly adrift
When you signed up for fibre what was the estimated speed
Re: Line Speed
02-06-2015 2:28 PM
You were estimated at 4mbps when you signed up to Fibre so at the moment you are getting above this.
However the estimated speed range for your line is between 4.4 and 8mbps so you won't be getting anywhere near 21mbps.
This will most likely be as fast as you will get.
Re: Line Speed
02-06-2015 3:41 PM
OldJim - It's as Matthew says - I was estimated at 3Mbps, but the BT line checker gave a range of between 4 and 8Mbps. Trust me, I am getting a 100% increase in speed which is good news for me. Long may it last. What did puzzle me though was the email fromPlusNet saying:
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 3Mbps
Current line speed: 21Mbps
You can keep a track of your line speed through our website:
When I saw the 21Mbps I was surprised, but felt I would need to check in case something had changed. I guess not...
I'm still intrigued to know what the 21Mbps is referring too.
