Line Speed down 7Mbps
CBR600
My download speed has reduced yet again.
My modem is saying the attainable is still the same however.
Previously my actual rate was almost identical to the attainable.
Attainable Rate (Kbps) 20066
Today !
 Download speedachieved during the test was - 12.63 Mbps
 For your connection, the acceptable range of speedsis 9.13 Mbps-13.04 Mbps .
 Additional Information:
 IP Profile for your line is - 13.04 Mbps
Can someone tell me whats going on please ?
J
Fixes: 167
Re: Line Speed down 7Mbps
Testing your line isn't showing anything obviously wrong other than the sync rate dropping. It's worth getting a fault reported at https://faults.plus.net ^CP
 Chris Parr
 Plusnet Staff
CBR600
The phone line does have some white noise on it so i tried raising a call but get this
Oops, something seems to have gone wrong
It looks like something has gone wrong. Our award-winning support team are here to help.
Call us on 0800 432 0200
CBR600
I've logged a fault but no response about it.
I have noticed what i think is the issue though.
Previously my SNR was 6.2 when i was getting a rate of 17877.
Now my SNR is 11.2 so it has nearly doubled.
Wouldn't that be caused by a fault on the line ?
Fixes: 167
Very likely. The SNR has probably increased to deal with the increased noise on the line.
Is the white noise still there? As your line is synced within the estimate range if we pass this through as a broadband fault it's likely to be rejected, so if the noise is still there on your phone line it's probably worth us looking at that route, however it's likely to need an engineer booking as testing isn't finding any issues.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 20 13.1 1.2 0.8 -- Available -- --
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 13.5 Mbps
Upstream Speed 1.1 Mbps
 Chris Parr
 Plusnet Staff
CBR600
Thanks Chris
I'll check the line when i get in.
It was very noisy last friday when i received a call that i had to call the person back.
They said they could also hear "white noise".
CBR600
How odd :/
Just checked again and its changed once more.
SNR is now 6.3
 Download speedachieved during the test was - 16.41 Mbps
 For your connection, the acceptable range of speedsis 11.97 Mbps-17.1 Mbps .
 IP Profile for your line is - 17.1 Mbps
Something weird is happening for it to jump around like that.
