Line Profile?
Line Profile?
My connection appears to be rock solid (no disconnects) and has been since installation (except power cuts etc) --  but the speed is lower than estimated originally , is there anyway Plus net can change the line profile to enable faster speeds , I'm not concerned if this causes minor disconnects.
Let me know what the upshot is..
Rob D
3 REPLIES 3
Fixes: 18
Re: Line Profile?
I've run some line test for you. You are, or have been G.INP'd. This should improve as BT roll-out updates for you.
The estimates themselves can be found in the availability checker. You are just about in the impacted range suggesting there might not be much done. When you had it installed, did the engineer install the extension?
 Tony T
Re: Line Profile?
Extension?
I do know what that means,  I have the ecolife HG612 box to the technicolor router these are straight of the converted BTOR new main socket.
Fixes: 399
Re: Line Profile?
I think Tony presumed you had a extension running from the main socket.
The speeds seem fine from what I can see as they should be around 7.2mbps.
Unfortunately it looks like your a long way away from your cabinet so the speeds won't get any higher.
 Matthew Wheeler
