Line Performance
- Line Performance
Line Performance
08-04-2015 11:59 PM
on a side note I have also noticed my ping has been rather erratic as opposed to the normal 10ms ping I used to receive.
Many thanks
Re: Line Performance
09-04-2015 12:05 AM
09-04-2015 12:09 AM
09-04-2015 7:40 AM
I had a problem with speed, and profile dropped by 10Mbps so i got a unlocked HG612 from ebay and all returned to normal soon as i powerd up the replacement HG612 modem, didn't need to call plusnet to fix my profile all back to normal.
09-04-2015 9:38 AM
thanks anyway,
p.s I finally understand G.INP
09-04-2015 11:43 AM
"0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Retransmission Low"
However your current sync speed is 60mbps so I would expect your speeds to be in the high 50's rather then the low 50's
What results do you get when you run the BT Speedtest below?
http://speedtest.btwholesale.com
09-04-2015 11:52 AM
Thanks.
09-04-2015 12:15 PM
Your profile is "0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Interleaving On" which means you have interleaving on your upstream and downstream.
This will account for the higher ping times and it's most likely been added due to errors on the line.
As long as the line stays error free in theory DLM will remove it in time but there isn't anything we can do remotely to remove it I'm afraid.
09-04-2015 12:24 PM
could the speed drop also be to do with the fact that I have an ECI modem connected to the HUWAEI cab? any news on a fix for this yet?
09-04-2015 5:25 PM
I guess the question now is trying to figure out what is causing errors on the line. Maybe once I have the stats I can start to hone in on that. Right now I can't quantify the errors, other than to say that interleaving is on.
The other curious thing, is that I understood G.INP rollout to be complete on Huwaei cabinets by the end of March. Does the information you gave Matthew mean that G.INP may be enabled on my cabinet, but it just isn't active on my line?
Thanks again.
