Line Check
goldenfibre
Seasoned Pro
Fixes: 12
Line Check
Hi PN
Can you please ran GEA Test for my FTTC and post to my ticket and also check if PN profile still set at 78Mb on their side.
3 REPLIES 3
Fixes: 1,102
Re: Line Check
Hi @goldenfibre
There are no open tickets so I'll post it here:
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 79.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Target Fix Time
Fault Report Advised N
Estimated Line Length In Metres 262.7
Upstream Rate Assessment Very Good
Technology VDSL
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2019-06-29T15:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 79.9 Mbps 79.9 Mbps 79.9 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 899.0 Sec 900.0 Sec 899.9 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-07-12T13:54:25Z 2019-07-12T14:09:25Z
Ingress Code Violation 0 1
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Your sync rate is perfectly fine and the connection profile is set correctly at 77mbps.
goldenfibre
Seasoned Pro
Fixes: 12
Re: Line Check
@Gandalf Thanks. I forget to open ticket as it didn't sent it. But, thanks anyway. Glad my line are stable for 15 days since last DLM with no errors on downstream side.
Fixes: 1,102
Re: Line Check
No problem that's cool and yup looking good Thumbs_Up
