Line Check Please
Scorpuk
Line Check Please
Been getting a lot of disconnects over past few days and ran the BT Wholesale checker this morning
1. Best Effort Test:  -provides background information.
Download Speed
7.31 Mbps
0 Mbps 12.01 Mbps
Max Achievable Speed
Download speedachieved during the test was - 7.31 Mbps
For your connection, the acceptable range of speedsis 8.41 Mbps-12.01 Mbps .
Additional Information:
IP Profile for your line is - 12.01 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.09 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 0.09Mbps
Upstream Rate IP profile on your line is - 10 Mbps
My IP Profile seems to be getting lower and lower each time I run the check. Used to always get around 22Mbps and when I ran it yesterday I got this: IP Profile for your line is - 15.28 Mbps
Could someone at PlusNet please run a line check for me?
Thank you.
Fixes: 162
Re: Line Check Please
I'm going to be honest and say I'm really not surprised your speeds have dropped from the sheer volume of disconnections the last 2 days:
The vast majority of the disconnections seem to happen at 1 minute 20seconds (give or take 5 seconds).
Stopping those disconnections is important before even looking at any speed problems. Has anything changed locally (either in your premises or local area) over the last 3 days? New electrical equipment, roadworks etc maybe.
 Chris Parr
 Plusnet Staff
Scorpuk
Cheers Chris.
Wow I knew it had been bad, but not that bad.
Only addition to the house has been an IP camera 2 weeks ago.
Haven't seen any road works either.
Scorpuk
Dont think it has bearing on the problem, but on checking my routers settings I came across this:
  • Delay disconnection by provider to the period between [3 - 4]
I've unchecked it now.
Fixes: 162
Good spot and it's worth seeing if it makes a difference. I can see our faults team have got your ticket so they'll investigate and respond asap.
 Chris Parr
 Plusnet Staff
Scorpuk
Currently disconnected and seen it go up and down all day.
Run team-viewer on computers at home and have seen them come on line multiple times.  Sad
Scorpuk
Changing that option in the router has made no difference.
Still getting multiple disconnects.
Attached the Fritz!Box log. It may be of help...  Huh
