Line Check Please
danludlow
Line Check Please
Can you check my connection and post the data please? All sound, and speed slightly increased in last two days, but IP profile on BTW Performance Test unaltered for last fortnight.
Thanks, Dan
Fixes: 231
Re: Line Check Please
I've attached a screenshot.
 Matthew Wheeler
Fixes: 21
Nothing wrong with the Upstream sync speed. Try logging off in the Router, wait 30 seconds and then Reboot the Router (not the Modem), and see if that helps.
danludlow
Thanks, will reboot the router and see what transpires, but later, after I've been out with The Mrs. who's keen to go somewhere.
