Line Check Please Speed Drop
- Re: Line Check Please Speed Drop
16-07-2015 9:59 PM
Broadband has halved in speed in the last couple of days is usually at least 68mb and now.
Estimated line speed:
Current line speed:
31.6 Mb
Current line speed:
31.6 Mb
Message 1 of 4
(651 Views)
3 REPLIES 3
16-07-2015 10:03 PM
Probably worth doing a test at http://speedtest.btwholesale.com/ and then running Further Diagnostics to get a BT profile. Post the speeds and BT profile from that test.
Message 2 of 4
(485 Views)
16-07-2015 10:18 PM
Download speed achieved during the test was - 25.83 Mbps
For your connection, the acceptable range of speeds is 40 Mbps-31.78 Mbps .
Additional Information:
IP Profile for your line is - 31.78 Mbps
Have had it a year or so and has never dropped below 68mb.
On Fibre Extra.
Where it says max speed of 40mbps has always been somewhere around 70mbps.
On Fibre Extra.
Message 3 of 4
(485 Views)
17-07-2015 11:15 AM
Our tests haven't found a fault although I can see there's been a huge drop.
If you can raise it using the link below our faults team can investigate.
https://faults.plus.net
Message 4 of 4
(485 Views)
