Limited/no internet connection
- Re: Limited/no internet connection
21-02-2015 4:52 PM
Hello,
over the past couple of weeks our household have been experiencing intermittent internet drops, Windows 11 machines report 'limited connection', Windows 7 'no internet connection', it also affects android and IOS devices. The BT HH5 troubleshooting reports we are connected to the internet but only a reset of out HH5 fixes the issue.
I can ping both the DNS servers,
C:\Users\gw>ping 212.159.6.10
Pinging 212.159.6.10 with 32 bytes of data:
Reply from 212.159.6.10: bytes=32 time=12ms TTL=59
Reply from 212.159.6.10: bytes=32 time=115ms TTL=59
Ping statistics for 212.159.6.10:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 12ms, Maximum = 115ms, Average = 37ms
C:\Users\gw>tracert 212.159.6.10
Tracing route to FWDR-10.FWDR-6.FWDR-159.FWDR-212 [212.159.6.10]
over a maximum of 30 hops:
1 2 ms 2 ms 2 ms BThomehub.home [192.168.1.254]
2 23 ms 11 ms 13 ms 195.166.128.183
3 12 ms 11 ms 11 ms 212.159.2.164
4 521 ms 11 ms 11 ms 212.159.0.196
5 12 ms 11 ms 11 ms 195.166.129.41
6 12 ms 11 ms 11 ms FWDR-10.FWDR-6.FWDR-159.FWDR-212 [212.159.6.10]
Trace complete.
But if I try to ping google:
C:\Users\gw>ping www.google.co.uk
Ping request could not find host www.google.co.uk. Please check the name and try
again.
Is this a DNS issue (I cannot change it on the HH5) anyone have any ideas before I unpack the Plusnet router and BTOR modem?
Gary
Trace complete.
again.
Gary
Message 1 of 6
(1,074 Views)
5 REPLIES 5
21-02-2015 4:55 PM
Have you tried setting the DNS servers in Windows rather than using the ones from the router
Message 2 of 6
(715 Views)
21-02-2015 5:02 PM
Hello Jim,
thanks for the reply, no I have not tried that as yet but I will try it next time (if I can stop the rest of the family resetting the router)!
Gary
Gary
Message 3 of 6
(715 Views)
23-02-2015 10:04 AM
Message 4 of 6
(715 Views)
25-02-2015 9:43 PM
Hello,
the same thing happened this morning, I followed Oldjim's advice and changed the DNS on my Windows laptop to 8.8.8.8 and my laptop connected ok.
Its a bit of a pain to change everything (android needs an app), any ideas as to what is causing this?
A hard reset solved the DNS issue as per usual.
Gary
Gary
Message 5 of 6
(715 Views)
26-02-2015 9:56 AM
Normally we'd recommend setting the DNS in the router to save you having to change it for each device.
I'm not sure if that's possible on a BT Home Hub although I'm sure someone else will know.
Message 6 of 6
(715 Views)
