Latency
Mickzyy
Latency
I have a latency of around 21 ms but it staggers from 21 to around 60. Is there any chance I can get set to annex a to have lower latency maintaining the same download speed and upload speed that I am currently on. Many thanks
Mickzyy
Re: Latency
If lowering the mtu from 1480 to around 1370 is possible could u also do that please as im under the impression it lowers latency thanks
etdsaunders
Fixes: 7
Re: Latency
Plusnet have no control over fibre, unlike ADSL. They can not remove interleaving remotely, it requires a BT engineer to reset DLM and that will only happen if you have a fault on your line
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs Up
rongtw
Fixes: 12
Re: Latency
Aparently PN new network gives you a lower latency Thumbs Up hopefully we will be switched over soon
etdsaunders
Fixes: 7
Re: Latency
It may give you lower latency but if DLM has set interleaving on you are unlikely to get pings of 7ms.
NorthEasterner
Re: Latency
I got a ping of 64ms yesterday and I just disconnected and reconnected the PPP session and that sorted it. :-/
NE
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
rongtw
Fixes: 12
Re: Latency
Must admit , a gateway hop normally gets a less occipied connection for a few days , games get lower pings then
etdsaunders
Fixes: 7
Re: Latency
I've never seen pings about 10ms since swapping to fibre. I get an average of 8ms
I'm not sure if I'm on new network, I couldn't tell you (using a static IP)
Re: Latency
I've been on fibre for more than 3 years and never had a ping of less than 20ms!Sad
My speeds are 73ish down and 18ish up on fibre 80/20.
Geoff,
York.
rongtw
Fixes: 12
Re: Latency
Ned , i am always below 20 ,, average is 12 - 15
http://www.speedtest.net/my-result/5250118563
Re: Latency
I just tested on the Bristol link which is the one I use all the time and :-
http://www.speedtest.net/my-result/5250138539
But, on Maidenhead I get :-
http://www.speedtest.net/my-result/5250135369
Perhaps I should use Maidenhead more? Thumbs Up
Geoff,
York.
etdsaunders
Fixes: 7
Re: Latency
I get same ping on Maidenhead and Maidstone(local)
http://www.speedtest.net/my-result/a/1871275884
