Latency went through roof afterwards it's sloooooooow
About 1pm yesterday I ran into treacle - latency reported by TBB was off the graph.
I powered everything down and when I reconnected my speed had dropped from between 30-35Mbps that I've had for last few weeks anytime of day
to between 10-20Mbps. I just re-tested and It's much the same this morning.
I'm on PCL-AG07 now and at the time I was on PCL-AG06 if that makes any difference. My upload always comes out at or near to 6.5Mbps.
Are things going to get better and is there anything I need to do?
1 REPLY 1
Re: Latency went through roof afterwards it's sloooooooow
I can see that the gateway is irrelevant as I've connected to several during the day and it made no difference. I'm still hovering around a speed that is only just within acceptable limits
Ho hum, at least I've got a connection - at the moment!
