Latency has gone from 20ms to 35ms>
- Latency has gone from 20ms to 35ms>
31-08-2021 9:17 AM
Any help would be greatly appreciated
Re: Latency has gone from 20ms to 35ms>
31-08-2021 9:26 AM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
31-08-2021 12:17 PM - edited 31-08-2021 12:18 PM
Hi @brownyy, thanks for getting in touch and I'm sorry to hear you've been seeing performance issues as of recent. When checking your account from this side I can see there current looks to be a profile banding meaning your missing out on a few Mbps with he download. I've adjusted this on the account correctly moving forwards however and you should see the speeds slightly increase.
Testing your connection from this side and seen by the graph below, we aren't detected anything out of place in regards to your connection or the the profile our suppliers side.
Test Outcome |
Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 37.1 Mbps |
Upstream Speed | 10.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 764.1 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Low |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | ;00:00to23:45 |
Interference Location | Customer Premise |
Interference Observed In Days | 14 |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream traffic detected |
Technology | VDSL |
DP Type | External |
Profile Name | 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off |
Time Stamp | 2021-08-18T12:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 37.0 Mbps | 39.9 Mbps | 39.9 Mbps |
Up Stream Line Rate | 9.9 Mbps | 9.9 Mbps | 9.9 Mbps |
Up Time | 785.0 Sec | 900.0 Sec | 899.8 Sec |
Retrains | 0.0 | 3.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2021-08-31T11:46:32.401+01:00 | 2021-08-31T12:01:32.401+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
I'd maybe check then to see if the ping increase you're seeing is across multiple devices as this may help narrow down the cause of the issue further. Let us know how it goes.
31-08-2021 12:32 PM
Cheers
31-08-2021 3:29 PM
Hi @brownyy, thanks for getting back to me. Looking at the profile for your line there currently doesn't look to be any error protection in place now any interleaving to help with errors.
The profile as seen below looks to e optimal for performance currently:
"0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off"
In regards to the performance issues you've been seeing, is this occuring solely over wireless devices or on wired connections also?
31-08-2021 3:35 PM - edited 31-08-2021 3:37 PM
@brownyy Your line has recently changed to a high depth of interleaving, note that the "interleaving low" profile in the GEA test has a timestamp of 18th August so is almost 2 weeks out of date. Unfortunately Plusnet have no control over line parameters on FTTC, it is all done by the Openreach automated DLM system. ☹️
@BD The current line profile is definitely not interleaving low!
06-09-2021 5:00 PM - edited 06-09-2021 5:05 PM
@BD Hi please could you take another look as for some reason the speeds have gone even slower and the ping as increased? My average speed is now 29Mbps and my ping is 35> I have a feeling my line has been banded. Could you do another GEA test for me?
thanks
06-09-2021 7:52 PM
Test Outcome | Pass |
Upstream Speed | 6.4 Mbps |
Technology | VDSL |
Time Stamp | 2021-08-24T20:00:00 |
Down Stream Line Rate | 32.2 Mbps | 39.9 Mbps | 37.8 Mbps |
Up Stream Line Rate | 6.3 Mbps | 9.9 Mbps | 9.8 Mbps |
Up Time | 743.0 Sec | 900.0 Sec | 899.6 Sec |
Start Time Stamp | 2021-09-06T19:31:42.092+01:00 | 2021-09-06T19:46:42.092+01:00 |
06-09-2021 7:54 PM
Hiya @brownyy, I'm sorry to hear you are having some issues.
I have provided a new GEA test for you. Your download is looking the same but the upload has decreased slightly.
06-09-2021 8:00 PM
when I run a wired speed test the max I get is 30Mbps. Is there anyway you can request a reset to the DLM? Hoping it will sort the interleaving out and take the downstream protection off to
Improve the ping like it did before.
Cheers
07-09-2021 5:21 AM - edited 07-09-2021 5:23 AM
Further to my last message. I have ran another test this morning on BT` Wholesale although it won't let me go into "additional Diagnostics" My speeds have degraded further. Now my download is around 7-10Mbps and upload 2-3Mbps ping 45.
Cheers
07-09-2021 11:08 AM
Good morning @brownyy
Thanks a lot for reaching out and I'm really sorry to see that this issue is getting worse. Tests on the line this morning have picked up similar results seen by my colleagues, the line is syncing at 37.1 Mbps (apparently), and the speeds have recovered from a recent drop off. I've been unable to get into the router though to check out some wireless settings, are you using the Hub One?
Just a quick note about the Broadband profile as well, DLM automatically adjusts this based on line performance, so for instance, there were 4 dropouts on Saturday, which is why, I'm assuming anyway, DLM increased the level back up to high.
Unfortunately, unlike ADSL2+, we're unable to make any manual adjustments to the DLM profile, other than requesting a speed banding reset, as your profile shows though, it's not banded.
Current Profile: Downstream: 0.128M-40M with Interleaving (High). Upstream: 0.128M-10M with no error protection
Please get back to me if you are using the Hub One as there's a few things I'd like to explore before making any further suggestions.
07-09-2021 11:25 AM
Cheers
07-09-2021 3:18 PM
Thanks for letting me know @brownyy , can you please send me a PM with your router's serial number and MAC address?
on
07-09-2021
4:04 PM
- last edited on
08-09-2021
11:04 AM
by
[Removed]
Moderators Note: Personal information removed
