Lag spikes and packet loss
chri55chofield
Hi
This is getting bad...hugs lag spikes on Overwatch and TF2 on my wired PC, same on 2 other 'powerlined' PC's in the house (DOTA2).....suspect faulty router from what I've read.......HELP!?
Fixes: 16
Re: Lag spikes and packet loss
Hi @chri55chofield
Thanks for getting in touch. Sorry to hear you're experiencing lag.
Could you run tracert and pathping on your PC (via the command prompt) and post the results here?
Info on both commands can be found here
Best Wishes,
Dave
 Dave G
chri55chofield
Hi and thanks for the response....
Attached are the details you requested plus a current run of PingPlotter.....
Fixes: 16
Hi Chris,
All of the results you've provided look fine.
I've arranged for a replacement router to be sent to you - let me know how you get on once you've got it set up and tested.
Thanks,
Dave
 Dave G
chri55chofield
Dave
Thanks for that....I look forward to testing and feeding back Cheesy
