LAN Port keeps dropping
szymonj99
Hello! I recently started having some problems with my connection. This all started just a few days ago - wish it went away already! The LAN port keeps dropping, not able to make a connection between my machine and the router. Any help would be appreciated. Attached a screenshot of the router page. Thanks!
Browni
Aspiring Hero
Fixes: 45
Re: LAN Port keeps dropping
Have you tried a different LAN port? Tried a different cable?
I must have been really bad in a previous life. This is my 3rd ISP in a row that uses lithium.
Now you lot are going to suffer because my current ISP doesn't run a forum Cheesy
szymonj99
Yes, tried two cables and two ports. None of which seem to work. Screenshot: LAN Port 1
Edit: I have tried a second machine too, and can confirm that it doesn't work either. two cables, all ports, two devices. Makes me think the router is at fault?
Champion
Fixes: 33
Is the wireless link stable? If so that would be further evidence that it's most probably a duff router.
szymonj99
Yes. All wireless links are stable and working.
Champion
Fixes: 33
The next step has got to be a replacement router. If you don't want to spend real money before being absolutely sure then get a cheap one from Ebay. It's always good to have a spare anyway.
szymonj99
Surprised I didn't think of that earlier. Have an BT HomeHub 5 laying around. Once I switch out the router, are there any settings I need to change? Thanks
Champion
Fixes: 33
szymonj99
Thansk for the help! Turns out, it is a faulty router. The Home Hub works perfectly! What steps should I take now? Would PlusNet send me a replacement router, or should I stick to the homehub/buy a new router?
Champion
Fixes: 33
The Plusnet Hub One is no more that a Home Hub 5a with a different coloured case and slightly tweeked firmware. Consequently if you are happy with your current set up then I would stick with it. If Plusnet will give you a hub for the cost of the postage then it's worth having one for a spare but it's not worth buying a new one.
I had a router do a similar thing to me. Internet worked over wi-fi (so not the connection), not through Ethernet. I think the switch in the router died.
As @Baldrick1 says if it can get hold of a cheapo spare, just for the peace of mind so you've got a backup available. Can't remember whether if PlusNet supply you one, you have to take out a new minimum length term.
There are plenty knocking around eBay though that don't cost much.
Browni
Aspiring Hero
Fixes: 45
Good to hear you've found the problem. Your edit in post #3 pretty much confirmed it was the router at fault.
Fixes: 346
Hi there. I'm sorry to hear you're experiencing connection problems.
As the router we've sent you is under warranty, I'll send a replacement out to you now and it should be with you soon.
Can you let us know how it goes when you receive it?
szymonj99
I'll keep you updated, and post a reply once I get my hands on the router. Thank you!
szymonj99
Received the router today, works flawlessly! Thank you! Should I send the old one back? Asking, since I got a blue return bag. Also, it was delivered to my previous address? Would you mind fixing that up for me, please? Yet again, huge thanks for reaching out to me.
