Kguard DVR SMTP Problems
keiron26
Hi
I am having issues with the SMTP email alert settings when i moved over to plusnet it stopped working and i got told by a friend that plusnet blocks smtp connections unless i use plusnet smtp server but i dont know how to set one up
someone please help me
Current settings
SSL off
SMTP Port: 587
SMTP SERVER: smtp.plus.net
SENDER EMAIL [Removed]
CANT GIVE PASSWORD
CANT GIVE RECEIVER EMAIL
but i can confirm both password and receiver email are correct
I keep getting unknown error or remote smtp server connection time-out!
i dunno what else to do
Moderator's note by Mike (Mav): Personal email removed from a public forum.
5 REPLIES 5
bobpullen
Fixes: 316
Re: Kguard DVR SMTP Problems
We don't block third party SMTP connections and your settings look OK. If you configure an email client like Outlook/Thunderbird to use these settings then does it work? I assume the DVR is connected to the Plusnet line, and that your account is activated/up and running? Do you have any success if you change the port to 25?
dannyboy75
SMTP testers can also be useful in these situations. SMTP Diagnostics is a fully functional trial version which I've used before:
http://www.whitepeaksoftware.com/smtp-diagnostics/
keiron26
Thank toy for your help the softwares like a dream and i know now the problem is with my dvr again thank you for your help dude Smiley
keiron26
HI
I have borrowed my friends DVR and that is having sack same issues im starting to think the hub 1 is somehow blocking the traffic for them dvrs smtp services why and how i dont know
Any ideas?
bobpullen
Fixes: 316
Do you have a GMail account? If you do, you could enable external access to that and try relaying through GMail's SMTP server. Might help narrow the cause. Other than that, there's what I suggested in reply 2 Wink
