Keeps disconnecting
- Keeps disconnecting
Keeps disconnecting
04-05-2016 12:37 PM
We've had plus.net for 6 months and so far the internet has been fine. However, this past week has seen the internet dropping every few minutes for 30 or so seconds at a time. This makes doing anything an absolute chore and as I work from home it is very annoying.
It mostly seems to happen early in the morning. I've noticed it from as early as 6am and it carries on disconnecting repeatedly until around 11am or so. Today however it is 12.30 and it is still happening.
The disconnects are happening over wireless with an Android mobile phone and a Mac laptop. Also with a Windows PC which is connected to the router via home plugs.
Nothing on our end has changed recently.
I filed an issue with support who checked the line over a few days and apparently there were no issues that they could see. I have also tried doing a factory reset on the router but that hasn't solved anything.
Any help?
Re: Keeps disconnecting
04-05-2016 1:41 PM
Are you on a ECI cabinet by chance and still have G.INP enabled?
Like yourself I've had a stable line until recently and the enabling of G.INP has caused frequent disconnects. I've had to increase my SNR to 8dB which has reduced my download speed from 64 to 57mbps just to regain some stability.
04-05-2016 1:51 PM
Does your routers log give any indication of what's happening?
eg is it dropped vdsl connections or is it wifi problems etc.
04-05-2016 2:00 PM
Simon: I have absolutely no idea I'm afraid!
npr: Where do I find these logs? I tried logging into my router via the ip address but can't see anywhere to get the logs from.
04-05-2016 3:14 PM
If your router has a log file I'm sure you would have found it in the GUI.
If it's Plusnets version of the homehub 5 then you should find the event log here:
homehub management pages > troubleshooting > helpdesk
04-05-2016 3:23 PM
This is what we have.
04-05-2016 3:48 PM
I don't think those routers have a event log.
Have you tried changing the wifi channel? But as you're also having problems via a home plug it doesn't sound like a wifi issue -- still worth testing other channels (test channel 1, 6 and 11 to see which is best)
04-05-2016 5:33 PM
I tried a couple of different channels earlier when it was playing up. The issue cleared itself up at around 2/3pm today however it is usually only in the morning when it happens for some reason.
I have set it to channel 1 for now and will see what happens in the morning.
05-05-2016 10:40 PM
Like @simoncraddock says, it could be the rollout of retransmission on ECI cabinets. If it is, you should hopefully see an improvement before the week is out.
05-05-2016 10:50 PM
The op said support could find no issues, so presumably that means PN's radius graph showed no dropped connections. If it's a g.inp issue would there not be disconnections showing?
06-05-2016 1:18 PM
