Keep using BT Home Hub 4 router or switch to Plusnet router
moh13
Hello,
I received my PlusNet router today, but Internet was activated yesterday so I just used the details to connect to the BT router. It is all working fine, so I'm hesitant switching the router to the new one. Will it make any difference?
Thanks.
1 REPLY
Fixes: 385
Re: Keep using BT Home Hub 4 router or switch to Plusnet router
Hello there and welcome aboard!
If your Home Hub is working fine for you I don't see any reason why you shouldn't continue to use it.
With that said, there shouldn't be much difference with Hub One as I believe it's based on a variant of the Home Hub anyway. If I was in this position, I'd personally keep it in a drawer for a spare just in case your router ever fails. Smiley
-Anoush
