Keep losing internet
- Keep losing internet
04-07-2021 8:52 PM
I've had the occasional drop out of internet but this weekend it's been frequent. The router keeps flashing red, I reset it, set everything up again and then it drops. I've tried factory reset which worked for a while the first time but now doesn't. The phone line is 18 months old installed via Plusnet. Not sure what else to try. Any ideas? Thanks
Re: Keep losing internet
04-07-2021 9:07 PM
Now I have an orange light with a lit up 'b' under it if that helps.
05-07-2021 10:09 AM
Hi - First check it's not your phone line causing issues - because if thats having problems so will your b/band
following lifted from another post
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone if you have one plugged into the test socket behind the face plate of the master socket. The line should be completely silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of your broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider.
05-07-2021 2:28 PM
Thanks for your post @kyla
I'm sorry for the issues you're having with your connection.
Line tests aren't showing the cause for this, so I'd recommend going through some troubleshooting steps by plugging your router into what's known as the test socket explained Here and if you're still having issues, I'd head on across to faults.plus.net to report a fault to us as we'll likely need to arrange an engineer visit to investigate further.
