Just wondering how
- Just wondering how
- « Previous
- 1
- 2
- Next »
Re: Just wondering how
15-09-2017 7:52 PM
Wonder if the cab has had vectoring enabled. Mine was done a few weeks ago.
See
https://community.plus.net/t5/My-Router/BT-Business-Hub-Strange-SNR-behaviour/m-p/1471848
for the detail. If yours was done at about the same time, that could explain the speed increase.
16-09-2017 10:06 PM
hmm will be interesting to see if the problem comes back if you drop back onto the 3db profile
i'm still suffering, a fair amount of the time it seems to go down when no even 'in use' like the middle of the night, although not sure what the youview box might be upto then
wish i could take the £65 gamble on getting an engineer out
30-09-2017 5:37 PM - edited 30-09-2017 5:44 PM
Well I can confirm that all that I have done has not fixed the issue. My router is still randomly disconnecting. Any further ideas?
I seem to remember reading that BT Hub 5A routers were prone to disconnecting. Can't remember why though. I believe the Pusnet Hub 1 is a BT Hub 5A. Could this be the same issue?
01-10-2017 1:22 AM
i'm still in the same/similar situation with about 1 drop a day, weirdly afterwards the snr stabilises
i've been using routerstats http://www.vwlowen.co.uk/RouterStatsHub/routerstatshub.htm
to watch what the snr has been doing, i can see it gradually degrade then disconnect then all goes to normal for about a day
doesn;t seem to be any obvious timing etc
in the end i got the engineer out, who saw it drop whilst he was testing, but found nothing at the house to the pole bit which all he does
it was supposed to be escalated, but i've had nothing from plusnet since which is frustrating, especially after the poor attitude over the £65
01-10-2017 6:56 AM
About 1 drop per day would not generally be considered a fault.
01-10-2017 5:05 PM
well nor true and as we are on IPTV, but unlike other providers we aren't given access to catchup, this means we don;t have a proper iptv service doesn't it
in any case plusnet were considering a fault
02-10-2017 12:39 PM
I don't get how 1 drop out a day can be considered normal? Your paying for a reliable service and, even 1 drop out a day, isn't that. I find my drop outs happen at random times and I am them as it's happening when I am doing something, so have a few minutes to wait till the router reconnects.
With regards to my previous post could this be the previously mentioned issue with the BT Hub 5 A dropping out on certain exhanges?
02-10-2017 7:14 PM
"The" issue tends to be so vague that anyone with a problem and who is using a HH 5A get lumped together as having "the" problem. The only way to know would be to try a different modem/router, you could either get yourself one, or see how much time and effort it takes (and how many more Plusnet Hub Ones they'll send) for Plusnet to supply you something different.
03-10-2017 12:33 AM
i wonder if plusnet are thinking about a rebadged hh6 yet? i'd be happy to trial one to see if it fixed the issue
to be honest starting to get a little worried about plusnet, had my ticket incorrectly marked as fixed today and misleading comments made to my partner over the phone
i've been with plusnet a long time and on the whole found them to be very good, maybe just being unlucky and i do understand that they as are most of us in the UK under the cosh of openreach...
- « Previous
- 1
- 2
- Next »
