Just upgraded from ADSL to FTTC - and speeds have gone down!
NicholasA
 My upgrade to fibre broadband happened yesterday - and my broadband speeds have deteriorated!  What is going on?
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
  Download Speed
  0.74 Mbps
0 Mbps 38.71 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.74 Mbps
 For your connection, the acceptable range of speedsis 27.1 Mbps-38.71 Mbps .
 Additional Information:
 IP Profile for your line is - 38.71 Mbps
  Upload Speed
  1.72 Mbps
0 Mbps 2 Mbps
Upload speed achieved during the test was - 1.72Mbps
 Upstream Rate IP profile on your line is - 2 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
MattyC
Champion
Fixes: 46
Re: Just upgraded from ADSL to FTTC - and speeds have gone down!
Do you mind checking again? Looks like your profile needed updating.
Matty
NicholasA
No.  Nothing has changed as far as I can see:
FAQ
  Download Speed
  1.63 Mbps
0 Mbps 38.71 Mbps
 Download speedachieved during the test was - 1.63 Mbps
  Upload Speed
  1.57 Mbps
0 Mbps 2 Mbps
Upload speed achieved during the test was - 1.57Mbps
Please visit the FAQ if you are unable to understand the test results.
Plusnet Staff
Plusnet Staff
HI, Sorry to hear of the issues with your speed.
Once you have completed the intial speed test and further diagnostics and your presented with the option to continue to carry out further testing please do so. This will ask you to change the login details on your router to use BT test logins.
Doing this will by pass any connection profiles we have in place and test the connection speed directly on the BT wholesale network. This is very helpful for us when testing the fault because we can pin point if the issue with something on our side of the network or if the issue is on the Wholesale network.
If it fails on the wholesale test let us know and we can get it reported.
 Peter Birt
 Plusnet Support Team
BrightonRock
Fixes: 6
@NicholasA
Did you restart your router before doing your second test? If Plusnet needed to reset it, the router might not have picked up the new profile without.
NicholasA
Oh yes!
Speed somewhat faster this morning - but need to go through the full suite of tests - and I need to find a quiet time to deal with that (when the rest of the household won't object to the wifi and the domestic phone lines being disconnected whilst I run the tests).
