Just upgraded - Not getting better speeds
waywardson
Like the title says i just got my fibre upgrade this morning but since then my speeds don't seem to have increased at all. Just wondering if this is normal for the first few days or if i need to let plusnet know about it?
I found a link in another thread to show my estimated speeds and my current speeds and this is what its showing
Estimated line speed:
35Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-07-07 00:36:53
Current line speed:
6.7 Mb
Any help and advice would be great.
Estragon
Re: Just upgraded - Not getting better speeds
Try a single disconnect for ten minutes of the connection, in your router GUI. The Current line speed seems not to have updated, but a disconnect may trigger it.
If not, what IP Profile does the BT Wholesale speed test give when you go to the Further Diagnostics?
waywardson
I tried a disconnect for 10 minutes and the speeds didn't change.
i checked the bt wholesale speed test and it says this :  IP Profile for your line is - 38.71 Mbps
What should i do guys?
waywardson
i just got off the online chat and they said my speed should increase over the next week. I thought it would take immediate effect but apparently not.
is it normal for the speeds to take a week to increase to what im expecting?Huh
Quote from: waywardson
Wait a while and the "current line speed" should update to match (roughly) the BT IP Profile.
If it hasn't by this time tomorrow call and point this out.
A week!  Grin
sjptd
Sounds as if there is an issue with your Plusnet profile not getting updated from the BT profile.
This is quite a common issue after upgrade from ADSL as the Plusnet systems seem somewhat erratic.
The chat assistant should have picked it up.
Try chat again, and be a bit more pushy.
Good luck.
waywardson
thats what i was thinking and i did ask if it had all been switched over properly but they were adamant it would improve over the week.
I'll try again and see what they say
sjptd
Quote from: sjptd
They should fix the profile immediately, and then another router (not modem) reconnect should fix things.
Good luck.
Fixes: 158
Your Plusnet profile needs a kick.
CRT have been a bit short staffed this morning but the people on Chat can do it.
Customer and Forum Moderator. Windows 10 Firefox 63.0 (64-bit)
waywardson
I got onto chat again and asked about my profile. I was told that it had just been switched a few minutes before and i would just need to restart my modem/router.
Restarted and i'm now getting about 37Mb on the speedtest so it seems to have worked! I don't like that i just seemed to have been fobbed off the first time i asked though but at least i'm getting the proper speeds now.
bustermissy1961
Well you have 14 days if your not happy before the time is up you can leave don't get hooked into a contract if you think your going to have problems.
Razorback
Seems like a training issue to me. The impression I sometimes get of some PN staff is that if they don’t know the answer they just make something up Cheesy
Fixes: 219
Glad to hear you got it sorted.
 Matthew Wheeler
