Just switched to Plusnet but broadband not working
Booiep
Switched to Plusnet the blue light is on the box but it’s not  working and the line is all crackerly. Can anyone help?
1 REPLY
Fixes: 195
Re: Just switched to Plusnet but broadband not working
Sorry to hear your connection isn't working.
It looks like your router is stuck in it's automated setup.
If you follow the steps below you should be able to get online
1) Open a browser
2) Enter 192.168.1.254 into the address bar
3) On the router's home screen, select 'Settings'
4) Enter the password. This is the 'Admin Password for Hub Manager' on the removable card on the rear of the router (it can also be found on the base of the router)Within the 'Settings' menu, select the 'Broadband' tab or 'Enter your broadband username and password'
5) On the following page, you must enter the broadband username and password (There is a 'show characters option on this page if you are struggling with entering the password)
6) Click the 'Connect' button. The power light should turn blue to indicate that there is an internet connection.
Let us know if you're still having issues after
 Matthew Wheeler
