Just returned to Plusnet and still have speed/sync issues after 14 days
- Just returned to Plusnet and still have speed/sync...
19-10-2018 10:12 AM
I decided to rejoin Plusnet after about a year away and before I switched I was syncing at about 70 down 20 up, the day the phone line switched over that dropped to 60 down 20 up.
I left it to see if the sync/speed would sort itself over the initial 14 day period but it hasn't and this morning I got the following email from Plusnet:
When you signed up for Plusnet Broadband, we gave you an estimated line speed range. Now that your broadband has been up and running for 14 days, we wanted to let you know your line speed as it stands today, as a comparison. | ||||||
I've not raised a ticket for this as I'm at work and I'll do that and the associated tests when I get home but could do with some help - I suspect Openreach have broken something when I switched over :(.
I'm not sure how the system thinks my current line speed is 78 as my router is only syncing at 60 😕
The email saying "Hey you've got 78Mbps" was the prompt for me to reach out for help lol.
Any help much appreciated!
Re: Just returned to Plusnet and still have speed/sync issues after 14 days
19-10-2018 11:09 AM
The e-mail you have received is some automated thing that gets sent out after 14 days and doesn't mean much. The estimated and minimum (MGALS) speeds are taken from the BT line checker so only estimates. The Current line speed is PlusNet's own line profile which appears to be set to the maximum and can limit your maximum speed but is not an actual speed, it should be updated by the BT wholesale line profile but in any case because of previous changes to PlusNet's network it does not control the speed for most customers (unless you have ordered a static public IP address).
So ignore that e-mail, your actual throughput speed is basically down to your sync speed which is dependent on line length and controlled by BT Openreach dynamic line management (DLM)
When a line is migrated DLM is reset so you go back to 6dB default noise margin and no retransmission (G.Inp) which is an improved error correction method. Removing these will reduce your sync speed considerably it should come back when DLM takes action, could be in a few days or maybe longer. So it's just a question of waiting for your speed to improve.
19-10-2018 3:03 PM
Hi @CJBlue, welcome back!
While what @RealAleMadrid is pretty much spot on, with the estimates for your connection being 67.5Mbps to 80Mbps and your connection currently being in sync at 60.9Mbps, I'd recommend going through our troubleshooting guides Here and if the speeds don't improve, please report a fault on your account over at https://faults.plus.net
If you do raise a fault via the link above, please let us know back here and we'll get the ticket picked up for you. Thanks.
23-10-2018 9:18 PM
Thanks @HarryB,
Didn't get a chance to do the troubleshooting until tonight:
One thing I've spotted is I get this strange alternating tone instead of the usual dialtone you would expect, I tried to attach a recording of it but it won't let me as it's a .m4a audio file. (I can send you it in a direct message if you like).
Other than that, here's some DSL stats from my router if that helps:
Receive Direction | Send Direction | ||
Max. DSLAM throughput | kbit/s | 80000 | 20000 |
Min. DSLAM throughput | kbit/s | 128 | 128 |
Attainable throughput | kbit/s | 60897 | 21289 |
Current throughput | kbit/s | 60897 | 20000 |
Seamless rate adaptation | off | off | |
Latency | 8 ms | fast | |
Impulse Noise Protection (INP) | 3 | 0 | |
G.INP | off | off | |
Signal-to-noise ratio | dB | 6 | 6 |
Bitswap | on | on | |
Line attenuation | dB | 15 | 13 |
approximate line length | m | 303 | |
Profile | 17a | ||
G.Vector | off | off | |
Carrier record | A43 | A43 |
I've raised a ticket for this (183862993) , during the questions I selected there was no dial tone as I got the alternating tone instead of what I expected , not sure if that was entirely the correct selection but there wasn't an option for "Strange Alternating Tone" instead.
I was able to dial the 17070 number and do the quiet line test.
Hope this helps find the fault.
23-10-2018 9:38 PM
Ok, ignore the dialtone thing - turns out it I had 1571 voicemails , not used to that so though it was an error , doh 😕
24-10-2018 11:37 AM
Hi @CJBlue, thanks for raising the fault. Ideally the option of 'there is a dial tone' needs to be selected otherwise it picks up you are raising a phone issue to us.
Not to worry however, I've raised this to our suppliers and updated the ticket here with the next steps.
Just let us know once you have responded and we will pick this up for you.
