Just moved from Sky - sync speed dropped
- Re: Just moved from Sky - sync speed dropped
22-01-2016 11:25 AM
Thanks,
Dave.
25-01-2016 9:56 AM
25-01-2016 10:33 AM
25-01-2016 11:17 AM
That said, with this particular issue stated above. He is able to get 76mbps to his modem. He is only getting 60mb. I too am capable of getting more than 60mbps, however I took am limited to that figure. Strangley my next door neighbour gets the full 80 as advertised from a different provider.
This is why i believe there are som underhand tactics going on.
25-01-2016 11:24 AM
25-01-2016 11:35 AM
Is your Openreach modem a ECI or Huawei one?
27-01-2016 11:27 AM
It's a Huawei modem connected directly to the master socket - there's no extension wiring in this house being a new build.
Noise margin is 6.2dB. Can't tell you what it was with Sky as the modem doesn't report it when g.inp is on.
I was a bit surprised because I didn't expect the speed to change at all, unless with Sky the modem was holding a higher speed with more errors until the resysnc which took it to where it should be.
Thanks,
Dave.
27-01-2016 11:38 AM
27-01-2016 3:01 PM
BTW, I'm still on DSL, not trolling, but just interested to hear why they moved.
27-01-2016 6:13 PM
Quote from: XenoGuy as they're LLU, they have their own equipment, hence better....
that's quite a leap to make!
27-01-2016 10:50 PM
Quote from: chenks76 that's quite a leap to make!
Isn't that what LLU is? Different (DSL/VDSL) equipment than BT? Ofc, not necessarily better than BT's but.
28-01-2016 9:46 AM
you still use the same openreach network from the exchange to your house regardless if it's LLU or not.
28-01-2016 2:56 PM
Quote Why did the OP move from Sky
Bill rocketed to over £50/month. They offered to reduce it but in the long run the 18 month contract with PlusNet worked out cheaper. And the internet is freshly piped from Yorkshire.
28-01-2016 2:59 PM
