Just moved from BT and lost 10M
steveacp
Hi guys
I moved from BT to plusnet on 23rd Oct
I was on holiday, so I arranged for neighbour to switch routers, as I stream from my home setup.
Plusnet router killed phone line when plugged in. This was left for 5 days until I came back.
It was a faulty cable, connecting the plus net router to the old BT cable cured the problem
BUT
my speed now is reduced. I am measuring speed using OOKLA on apple TV 4K into GIGAbit ethernet port on the plus net router.
Speeds with BT were typically ping 9, 65M down, 13.5 up. speed with plus net ... ping 9 - 55M down, 12.5 up.
I reconfigured old BT router for plus net, and got same results
BT sync was just over 71.
I was thinking maybe the faulty cable pushed the speed down.
Can we try a profile that forces higher speed please.
Nothing else has changed, everything is in the same place, plugged into openreach mk 3 master socket, no extensions.
Steve
6 REPLIES 6
adamwalker
Fixes: 221
Re: Just moved from BT and lost 10M
Hi there!
I've just checked your account and unfortunately there isn't anything we can do to push anything through that will bring the speeds back to what you'd expect but the process of DLM (automated/dynamic line management) should correct that over the course of the next few days.
Do let us know if not so we can take another look.
 Adam Walker
steveacp
Thanks Adam, I’ll check again this weekend and let you know.
Steve
Strat
Fixes: 565
Moderator's note by Dick (Strat) Thread moved to a more appropriate board.
steveacp
Nothing much happened for first 2 weeks, now speed has gradually increased to 68 down, 13 up, which is as good as it has ever been.
Thanks, Panic over!
Steve
Mav
Fixes: 515
Moderator's note by Mike (Mav): I have changed the fix to @adamwalker as per message #2.
Forum Moderator and Customer
fwdlink
Same for me, I'm 12 days and going with quite poor speed, I was 80/20 and now 73/19.  I posted yesterday with my stats and what has happened thus far.  For me the DLM has taken no action on my line since the transfer, it's running free and wild and one post mentioned that as I'm FastPath at the moment could also result in speed loss.  I'm waiting and hoping it improves soon as I've lost over 10meg in effective speed now was 77-78 now 65-67 using speedtest.net
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
