Just how bad can plusnet get?
beves
Well it's been a week with no internet. Engineer didn't show yesterday and no explanation.
Initial fault not registered til 24 hrs after first contact.
If not sorted today I'm going Virgin.
Cowboys.....
Fixes: 254
Re: Just how bad can plusnet get?
Sorry to hear that.
It looks like the engineer did pick up the job, but didn't contact you. Apologies for the inconvenience caused.
Our tests are now showing your modem in sync to the cabinet. Can you factory reset your router?
beves
So late evening finally got a techy guy to talk me through resetting internet password in the router.
Disappointed that there was no proactiveness in contacting me after the fix at the exchange.
Hi @beves
Sorry for the issues you encountered and inconvenience this caused. I'll make sure your feedback is passed on.
If you need any further help in the future don't hesitate to get back in contact.
 Alice Baillie
