Just heard Plusnet now have a Hub.
- Just heard Plusnet now have a Hub.
- « Previous
- 1
- 2
- Next »
Re: Just heard Plusnet now have a Hub.
26-02-2016 11:14 PM
27-02-2016 7:13 AM
I have a new build 3 story house and the WiFi is fine works fine streaming to the top floor,
No lag on the xbox one while playing online
2.4 signal works alot better over distance than 5g but Imo it's a good solid router
27-02-2016 8:45 AM
I'll come back once it has been set up to let people know how the wifi compares with the Netgear.
27-02-2016 12:09 PM
podman
27-02-2016 2:29 PM
27-02-2016 6:06 PM
When it works - it's fine.
Seems Support at PN or BT don't get you to the right level of Tech Support to go through what's happening.
Recorded events
Time and date Message
17:29:21, 27 Feb. ( 1421.110000) CWMP: session completed successfully
17:29:10, 27 Feb. ( 1410.570000) CWMP: Set Parameter by TR069 Success
27-02-2016 6:28 PM
27-02-2016 8:07 PM
ref https://tools.ietf.org/html/rfc1918 (detailed) - https://en.wikipedia.org/wiki/Private_network (less detailed)
So generally you wouldn't need it, unless doing something that requires a specific IP address for a particular device on the "inside" separate to all your other devices... This is NAT (Network Address Translation - one to one) which the PNH1 can't seem to do. The BTHH5 can...(what they call "Multi NAT" - a misnomer but does describe it...
Hope this helps...
27-02-2016 8:11 PM
Quote from: chenks76
Quote from: Timalay Not close to the same spec as Plusnet's Hub One in my honest opinion.
very true. the billion is far superior
We will have agree to disagree.
27-02-2016 11:28 PM
Does such a thing as a smart phone switch seamlessly between ac and n (5GHz and 2.4GHz) as the higher frequency weakens with shielding and distance?
28-02-2016 6:10 AM
Quote from: HughPH You're allowed to have an opinion, but what about some analysis?
What are the features of each? What are the actual specifications of each? With so many people saying the 8800NL is "better," there must be measurable differences between the two. Is it just grass-is-greener? Or is it the placebo effect? Or is one actually better than the other?
If you have information, please post sources - otherwise you're no better than an audiophile, conspiracy theorist or used car salesman.
I can't give full specs for each but can say that a quick look online shows many Billion 8800NL users suffer from poor wifi performance, however it's highly recommended when used just as a modem especially for ADSL as you can adjust the SNR margin. The Plusnet Hub One offers better wifi coverage with dual band 2.4ghz and 5ghz N Speeds upto 300mbps and AC speeds up 1300mbps, it also has 4 Gigabit ethernet ports. The 8800NL only has 2.4ghz wifi and upto 300mbps and also only has 1 gigabit ethernet port. The Hub One uses a Lantiq chipset VS the billion which uses a broadcom chipset. I have a Plusnet Hub One and just wish they would allow the option of custom DNS servers, it can be done as the BT Home Hub business versions has this option.
06-03-2016 11:18 PM
Attempting to use the BTHH5 one can get this to work until the BT auth/TR69 service decides it wants to reboot the device. Then it does not connect again. I guess that the BTHH5's serial number is still in BT's TR69 database, with no way to get it removed. At least PN provides a mechanism to disable TR69...
If anyone knows how to achieve this with BT it would be very helpful.... Have tried Netgear Nighthawk and Asus DSL-AC68U... both to no avail. (BT blame PN, PN blame BT...round and round we go)
06-03-2016 11:46 PM
The wifi coverage seems somewhat improved upon the old Netgear DGN300 I was using instead of the rubbish Technicolor thing PN supplied last time.
Interestingly, the external IP may be dynamic, but the local IP addresses can be set fixed if you like, so now my wifi printer will hopefully not keep getting lost and needing re-boots to reconnect the wifi. Mobile phones and such don't seem to suffer that way, being happy to re-negotiate a dynamic IP whenever necessary.
The most useful function I've found so far is the ability to turn the LED indicator to 'DIM'. The LEDs are so bright, a double layer of white tape over them still didn't stop the glare, but setting to dim, together with the white tape, gives a gentle coloured glow just strong enough to show it's still functioning correctly.
Whether I will ever get a fibre connection still lays with the gods of internet obfuscation. Similarly, if I cancel the contract through not getting the connection, I suppose I may be asked to return the router.
- « Previous
- 1
- 2
- Next »
