Just had Fibre Installed - How long to increase linespeed?
minkey
Hi.
The fibre engineer has been today and upgraded my line. I'm syncing at 41,000 but my linespeed is still 5.2. How long does it take for PlusNet to increase my linespeed?
Jeff
Telephone number:012
Phone exchange:BISHOPS STORTFORD
Estimated line speed:35Mb (Download speed could vary depending on line conditions.
Estimates are the maximum speeds that your phone line can support.
These speeds are dependent on the package you choose.)  - Checked on 2015-08-04 15:04:00
Current line speed:5.2 Mb
Re: Just had Fibre Installed - How long to increase linespeed?
1) the line speed sets off at max no 10 days learning
2) it looks like your speed has not been reset from ADSL.
Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Fixes: 231
I've updated it for you now.
If you log into your router and disconnect then reconnect you should see a increase.
 Matthew Wheeler
minkey
Perfect. Thank you very much  Smiley
