Just connected new router - disappointing speeds
MissMunro
Hi all, just received my new fibre router which promised speeds of 35mbps+ but a speed test has shown speeds equal to my old service of around 2.5MBPS! Have I missed a step or have I been duped?
SpendLessTime
Aspiring Hero
Fixes: 63
Re: Just connected new router - disappointing speeds
@MissMunro
Welcome to the forums.
Have Plusnet told you that the service is live ?
the Plusnet Hub One works on ADSL as well as FTTC so you might be seeing ADSL speeds as you are still on ADSL.
Log onto the router (details here https://www.plus.net/help/broadband/router-user-guides/ if needed), go to the Helpdesk and click on troubleshooting to get a list of details.
Check what does it say for
23. Modulation: G.993.2 Annex B
If it contains "G.992." then you have not yet been upgraded to FTTC. If it says "G.993." then you have an issue as 993 modulation is FTTC but 992 is ADSL
MissMunro
Thanks, no have not had confirmation of new connection so possible it hasn't been activated yet. Will try to log in and have a look Smiley
MissMunro
Ok so the Modulation says G.992.1 so I'm guessing the service hasn't been activated. Will keep an eye on it and get in touch with them if I don't hear soon. Thanks again
SpendLessTime
Aspiring Hero
Fixes: 63
@MissMunro
You're welcome.
If you want to see where I got the modulation information from, it was at http://www.kitz.co.uk/adsl/linestats_explanation.htm
  ADSL1 ADSL2 ADSL2+ VDSL VDSL2
Standard G.992.1 (G.DMT) G.992.3 G.992.5 G.993.1 G.993.2
Max Downstream 8 Mbps 12 Mbps 24 Mbps 40 Mbps 80 Mbps
Fixes: 67
Hi MissMunro,
You're due to be upgraded to fibre tomorrow.
Just drop a reply back here if there's any issues and we'll get on the case.
 Adam Walker
MissMunro
That's exciting! Thanks for letting me know
Fixes: 67
No worries, just had a quick look at your account and can see that you're online now.
 Adam Walker
