Jitter at Gateway
redbull2k14
Jitter at Gateway
Do i have a problem if i have jitter at the gateway? i play online games but this example is just to google
Fixes: 4
Re: Jitter at Gateway
What is your buffer bloat like using the either 12/4 streams or the dsl option ?
Fixes: 4
Here are my averages from three seperate boxs testing my router bbc.co.uk and thinkbroadband.com bearing in mind I have an 850 meter line.
Some stats.....
DSLAM/MSAN type:        	BDCM:0xa48c / v0xa48c
Modem/router firmware:  	AnnexA version - A2pv6C038m.d24j
DSL mode:               	VDSL2 Profile 17a
Status:                 	Showtime
Uptime:                 	54 days 1 hour 57 min 21 sec
Resyncs:                	0 (since 10 Feb 2017 19:45:38)
				Downstream	Upstream
Line attenuation (dB):  	24.3		0.0
Signal attenuation (dB):	Not monitored
Connection speed (kbps):	40000		2000
SNR margin (dB):        	9.9		17.1
Power (dBm):            	11.2		0.8
Interleave depth:       	16		1
INP:                    	45.00		0
G.INP:                  	Enabled		Not enabled
Vectoring status:       	5 (VECT_UNCONFIGURED)
RSCorr/RS (%):          	0.1155		0.0287
RSUnCorr/RS (%):        	0.0000		0.0000
ES/hour:                	0		0
redbull2k14
i will check dsl reports when i next game.
What console app is that? and for what O/S,
Fixes: 4
Terminals (Linux) running mtr
I have tried the windows version but it's pretty awful!
