Jitter at Gateway
- Re: Jitter at Gateway
Jitter at Gateway
10-02-2017 11:06 AM
Do i have a problem if i have jitter at the gateway? i play online games but this example is just to google
10-02-2017 7:21 PM
10-02-2017 7:42 PM - edited 10-02-2017 7:50 PM
Here are my averages from three seperate boxs testing my router bbc.co.uk and thinkbroadband.com bearing in mind I have an 850 meter line.
Some stats.....
DSLAM/MSAN type: BDCM:0xa48c / v0xa48c Modem/router firmware: AnnexA version - A2pv6C038m.d24j DSL mode: VDSL2 Profile 17a Status: Showtime Uptime: 54 days 1 hour 57 min 21 sec Resyncs: 0 (since 10 Feb 2017 19:45:38) Downstream Upstream Line attenuation (dB): 24.3 0.0 Signal attenuation (dB): Not monitored Connection speed (kbps): 40000 2000 SNR margin (dB): 9.9 17.1 Power (dBm): 11.2 0.8 Interleave depth: 16 1 INP: 45.00 0 G.INP: Enabled Not enabled Vectoring status: 5 (VECT_UNCONFIGURED) RSCorr/RS (%): 0.1155 0.0287 RSUnCorr/RS (%): 0.0000 0.0000 ES/hour: 0 0
10-02-2017 9:30 PM
i will check dsl reports when i next game.
What console app is that? and for what O/S,
11-02-2017 12:06 PM - edited 11-02-2017 12:07 PM
