Issues with VDSL connection
meanioni
Hi, this weekend have been experiencing a lot of issues with my VDSL broadband connection. Several outages and whilst it is up currently, the ping times for connection/latency are now long - over 300ms compared to a normal of 20 - 30ms. I have changed DNS from Google to OpenDNS and it made no difference. Is there a problem? Based in Lewes, East Sussex
6 REPLIES 6
Muzzm4n
Re: Issues with VDSL connection
I'm having the same problem. Based in Seaford, East Sussex.
RichardB
Champion
Fixes: 34
Hi @meanioni
I would suggest that you follow the troubleshooting at:
https://www.plus.net/help/broadband/connection-troubleshooting/
and if required follow the fault process at:
https://faults.plus.net
meanioni
Thanks but this is not an issue my end as nothing has changed. I know it is an issue with you, the ISP as when I use a VPN on the line, the latency improves. Also born out by the other forum member who appears to live about 5 miles away and is having similar issues. I work in IT so do know my stuff!!!
Aspiring Legend
Fixes: 162
@Muzzm4n , @meanioni  - put your phone number in here:https://status.zen.co.uk/broadband/ and see if there are any issues reported.
dusan_h
thanks for the link, Sheffield Manor just lost internet, fibre. Although I entered my phone number it didn't report any problem, but I can see an issue in Intake? I assume that's Sheffield intake, so it would be Manor area.
https://status.zen.co.uk/broadband/fault-outage-details.aspx?reference=31043
Aspiring Legend
Fixes: 162
@dusan_h Correct - and would possibly affect you.
