Issues accessing numerous sites
khaled35
For several weeks now I have been having issues accessing numerous sites.  I didn't think much of it but it now starting to get really annoying.
Sites like google.co.uk etc, just won't load.  When a run a tracert to the site, this is what I get:
Tracing route to www.google.co.uk [212.56.71.94]
over a maximum of 30 hops:
 1    <1 ms    <1 ms    <1 ms  router.asus.com [192.168.1.1]
 2    18 ms    18 ms    20 ms  195.166.130.217
 3    25 ms    19 ms    19 ms  link10-central10.pcl-gw02.plus.net [84.93.249.210]
 4    20 ms    17 ms    17 ms  ae1.pcl-cr02.plus.net [195.166.129.3]
 5    22 ms    24 ms    19 ms  plusnet-lcy4.plus.net [212.56.71.94]
Trace complete.
A few seconds later and the site loads again.  Anyone else having similar issues?  I am on a static IP and have been for several years.
I am using an Asus RT-N66U (latest firmware).
Cheers
10 REPLIES 10
khaled35
Re: Issues accessing numerous sites
Any chance of a response from someone at PN?  Posted this a while ago but haven't had a reply.
Chris
Legend
Fixes: 169
Testing your line is showing no obvious issues. Looking at your usage, that would suggest that the connection is working fine by the amounts transferred so far this month.
Do the sites load at all, just slowly or not at all?
khaled35
Hi Chris,
Sometimes they load slowly, sometimes the part load and sometimes I get a timeout.
Using google as an example, I can type in a search query, hit the search button, it will load the header of the page and then stall.  This isn't isolated to a single browser as it happens on Chrome, Firefox, IE11 and Edge.
Oldjim
Resting Legend
Fixes: 63
This looks a bit like a DNS problem
Which DNS servers are you using
khaled35
Hi Oldjim,
I've used the option to connect to DNS servers automatically but have also tried google's DNS and opendns and faced similar issues.
Cheers
khaled35
Just thought I'd throw this bit of information out there.  Using the BTW speed test, my latency is always between 35-45ms.  Seems a tad high but maybe it's not unusual?
stuartgreen
If the pages were slow to appear initially I'd say it might be DNS but if it's the page loading slowly overall that wouldn't usually be DNS. If you run a pathping to the webserver you've having problems with it might show you if there are any steps along the way that are losing packets.
So from a command window run 'pathping www.bbc.co.uk'; for example and let it run for about 5 mins. Then it will come back with a table like you get with a trace route but with more info about if any of the hops are dropping packets which could explain your slow loading times.
khaled35
Here's a few:
Tracing route to google.co.uk [216.58.213.163]
  0  MY-PC [192.168.1.65]
  1  router.asus.com [192.168.1.1]
  2  lo0-central10.ptw-ag02.plus.net [195.166.128.196]
  3  link-a-central10.ptw-gw01.plus.net [212.159.2.148]
  4  xe-0-2-0.ptw-cr01.plus.net [212.159.0.248]
  5  72.14.222.97
  6  216.239.48.89
  7  209.85.252.179
  8  lhr26s02-in-f3.1e100.net [216.58.213.163]
Computing statistics for 200 seconds...
            Source to Here  This Node/Link
Hop  RTT    Lost/Sent = Pct  Lost/Sent = Pct  Address
  0                                          Khaled-PC [192.168.1.65]
                                0/ 100 =  0%  |
  1    0ms    0/ 100 =  0%    0/ 100 =  0%  router.asus.com [192.168.1.1]
                                0/ 100 =  0%  |
  2  21ms    0/ 100 =  0%    0/ 100 =  0%  lo0-central10.ptw-ag02.plus.net [195.166.128.196]
                                0/ 100 =  0%  |
  3  18ms    0/ 100 =  0%    0/ 100 =  0%  link-a-central10.ptw-gw01.plus.net [212.159.2.148]
                                0/ 100 =  0%  |
  4  20ms    0/ 100 =  0%    0/ 100 =  0%  xe-0-2-0.ptw-cr01.plus.net [212.159.0.248]
                                0/ 100 =  0%  |
  5  18ms    0/ 100 =  0%    0/ 100 =  0%  72.14.222.97
                                0/ 100 =  0%  |
  6  18ms    0/ 100 =  0%    0/ 100 =  0%  216.239.48.89
                                0/ 100 =  0%  |
  7  ---    100/ 100 =100%  100/ 100 =100%  209.85.252.179
                                0/ 100 =  0%  |
  8  18ms    0/ 100 =  0%    0/ 100 =  0%  lhr26s02-in-f3.1e100.net [216.58.213.163]
Trace complete.
Tracing route to HOSTED-BY.VIRTUALXS.COM [62.129.131.50]
  3  link-b-central10.ptw-gw02.plus.net [212.159.2.150]
  4  xe-0-2-0.ptw-cr02.plus.net [212.159.0.250]
  5  195.99.126.182
  6  core1-te-0-15-0-6.ilford.ukcore.bt.net [109.159.254.53]
  7  peer5-te0-10-0-16.telehouse.ukcore.bt.net [109.159.255.93]
  8  t2c4-et-3-3-0-0.uk-lon1.eu.bt.net [166.49.211.246]
  9  t2c4-xe-1-0-1-0.nl-ams2.eu.bt.net [166.49.208.230]
10  166-49-153-214.eu.bt.net [166.49.153.214]
11    *        *        *
Computing statistics for 250 seconds...
                                0/ 100 =  0%  |
                                0/ 100 =  0%  |
  2  23ms    0/ 100 =  0%    0/ 100 =  0%  lo0-central10.ptw-ag02.plus.net [195.166.128.196]
                                0/ 100 =  0%  |
  3  18ms    0/ 100 =  0%    0/ 100 =  0%  link-b-central10.ptw-gw02.plus.net [212.159.2.150]
                                0/ 100 =  0%  |
  4  20ms    0/ 100 =  0%    0/ 100 =  0%  xe-0-2-0.ptw-cr02.plus.net [212.159.0.250]
                                0/ 100 =  0%  |
  5  ---    100/ 100 =100%  100/ 100 =100%  195.99.126.182
                                0/ 100 =  0%  |
  6  ---    100/ 100 =100%  100/ 100 =100%  core1-te-0-15-0-6.ilford.ukcore.bt.net [109.159.254.53]
                                0/ 100 =  0%  |
  7  ---    100/ 100 =100%  100/ 100 =100%  peer5-te0-10-0-16.telehouse.ukcore.bt.net [109.159.255.93]
                                0/ 100 =  0%  |
  8  19ms    0/ 100 =  0%    0/ 100 =  0%  t2c4-et-3-3-0-0.uk-lon1.eu.bt.net [166.49.211.246]
                                0/ 100 =  0%  |
  9  27ms    0/ 100 =  0%    0/ 100 =  0%  t2c4-xe-1-0-1-0.nl-ams2.eu.bt.net [166.49.208.230]
                                0/ 100 =  0%  |
10  30ms    0/ 100 =  0%    0/ 100 =  0%  166-49-153-214.eu.bt.net [166.49.153.214]
Trace complete.
Tracing route to bbc.co.uk [212.58.244.22]
  5  ae2.ptw-cr01.plus.net [195.166.129.4]
  6  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
  7    *        *        *
Computing statistics for 150 seconds...
                                0/ 100 =  0%  |
                                0/ 100 =  0%  |
  2  26ms    0/ 100 =  0%    0/ 100 =  0%  lo0-central10.ptw-ag02.plus.net [195.166.128.196]
                                0/ 100 =  0%  |
                                0/ 100 =  0%  |
  4  22ms    0/ 100 =  0%    0/ 100 =  0%  xe-0-2-0.ptw-cr02.plus.net [212.159.0.250]
                                0/ 100 =  0%  |
  5  21ms    0/ 100 =  0%    0/ 100 =  0%  ae2.ptw-cr01.plus.net [195.166.129.4]
                                0/ 100 =  0%  |
  6  18ms    0/ 100 =  0%    0/ 100 =  0%  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
Trace complete.
Chris
Legend
Fixes: 169
This is an odd one, nothing particularly wrong with the traces and as you've tried different DNS servers that should rule them out.
Is this on one device or multiple? Updated any security software recently? Do you have the router firewall turned on?
khaled35
Hi Chris,
This happens on multiple devices; I have tested on 4 to be precise.  2 hardwired windows machines and 2 machines connected via wifi.
I have also tested with my security software (Kaspersky Internet Security 2016) on and with it off.
Furthermore, I have tested with my ASUS router and with the Plusnet provided Technicolour router. All tests with the ASUS router were with the firewall on.  I'm not sure about the Technicolour router but I didn't make any changes to it so it was a default setup.
Thank you for looking into this for me.
