Is the Pro Add on worth having?
Kryten
I was just wondering if anyone (other than PlusNet staff) would recommend the Pro Add on at £5 a month?
Fixes: 10
Re: Is the Pro Add on worth having?
If you are on an Unlimited account - NO!
I've referred to this in my Why I have left Plusnet post.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
rongtw
Fixes: 12
NO !!!!!!
Kryten
Well, it seems as though that's a resounding NO. Very good, in-depth post btw Jelv. Thanks for the reply. I used to be with Zen years ago so I may have a look at what they're offering for unlimited.
