Is my upload being restricted for some reason ?
FIXED- Subscribe to RSS Feed
- Is my upload being restricted for some reason ?
06-07-2016 10:48 AM - edited 06-07-2016 10:52 AM
I moved from a 40/20 Unlimted service to 80/20 Extra last month. Both were giving me about 13Mbps UP (Ookla Speedtest), it dropped to 11Mbps about 10 days ago, now hovers around 10Mbps. Downlink Speed is a steady 47Mbps at the PC, 48Mbps or so at the socket.
According to distance from Cabinet I'm faster than I ought to be Down and I wouldn't want to change a thing, but the various changes of speed or ratio between Up and Down puzzle me. Broadband is an odd thing, unlike electricity or even water, it is not a predictable service. I guess in the end it's radio waves. Sometimes you can't receive close signals when a distant one comes in quite strongly.
Fixed! Go to the fix.
06-07-2016 12:05 PM
Doesn't look like we're restricting you.
Currently in sync at 51Mbps Down and 11.4Mbps Up.
Comparing this to the estimates for your line, it seems fine.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0001 |
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 51.0 Mbps |
Upstream Speed | 11.4 Mbps |
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Range(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
Left in Jumper |
High | Low | High | Low | |||||
VDSL Range A (Clean) | 56 | 43 | 11.3 | 7.5 | -- | Available | -- | -- |
Re: Is my upload being restricted for some reason ?
06-07-2016 12:25 PM
Thanks HarryB, I was curious, it seemed to fit the new BT 50/10 service. I'm very happy with the current service, hoping that it endures! ^-)
