Is my router faulty or equipment?
azamac
My sky q box keeps disconecting from the router is there any where in the router settings that i can have a look and determine what is happening? I dont seem to have any problems when using my phone
6 REPLIES 6
azamac
Re: Is my router faulty or equipment?
Here is a screen shot any one kbow the crack?
bobpullen
Fixes: 316
There seem to be three separate devices doing the same thing based on the MAC addresses. Is it a Hub One you're using?
Edit: Also, what version of firmware are you running? It will tell you in the footer of the router admin pages.
azamac
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2
Is what it says at the bottom
bobpullen
Fixes: 316
Not what I thought it might be then. Worth accessing the wireless settings and seeing if things improve with the 5GHz band disabled (it will affect high speed, short range connectivity but would be useful in trying to isolate the issue). Let me know if you need any guidance.
azamac
Disabled 5ghz but still the problem is there
azamac
Any one got any ideas on this one ? Really need to know if its my router or something else
