Is my ping high
- Is my ping high
Is my ping high
07-03-2017 6:15 PM
My broadband seems to be lagging tryed a speed test and getting a ping of 256ms...Is this normal.
Re: Is my ping high
07-03-2017 6:21 PM
256 is too high how did you test this WIFI or wired ?
Re: Is my ping high
07-03-2017 6:22 PM
Is that ping high while your doing a speedtest ?
Re: Is my ping high
07-03-2017 6:42 PM
Re: Is my ping high
07-03-2017 6:46 PM
Can you check wired connection ?
Re: Is my ping high
07-03-2017 6:49 PM
Re: Is my ping high
07-03-2017 7:01 PM
I was asking because if your network is busy, you would see a raised ping due to buffer bloat.
That said, here is a quick test on my laptop which is using WiFi.
Packets Pings Host Loss% Snt Last Avg Best Wrst StDev 1. intesting.testing 0.0% 25 1.0 1.5 1.0 3.5 0.4 2. lo0.central10.psb-bng04.plus.net 0.0% 25 14.1 14.7 13.6 17.4 0.9 3. 411.be8.psb-ir01.plus.net 0.0% 25 16.6 16.6 15.9 17.6 0.0 4. core1-BE1.southbank.ukcore.bt.ne 0.0% 24 16.2 16.5 15.2 17.2 0.0 5. peer5-hu0-11-0-1.telehouse.ukcor 0.0% 24 15.0 15.3 14.6 17.6 0.6 6. 194.74.65.42 0.0% 24 15.8 15.1 14.6 15.8 0.0 7. ??? 8. ??? 9. ae0.er02.telhc.bbc.co.uk 0.0% 24 15.4 15.7 14.9 17.1 0.4 10. 132.185.255.148 0.0% 24 16.7 16.5 15.5 22.6 1.4 11. 212.58.244.23 0.0% 24 14.8 14.9 14.4 16.1 0.2
Always best to do tests while A your network is quite and B as mentioned by using an ethernet lead straight into your router.
I've had some strange slowing down of general browsing and have managed to figure out that for me anyway it depends which gateway I'm as to how things are performing etc...
Re: Is my ping high
07-03-2017 7:20 PM
What was that speed checker you used.
Re: Is my ping high
07-03-2017 7:22 PM - edited 07-03-2017 7:24 PM
