Is my fault closed or not? Question #131886770
stoswald
Hi Team
I had a fault on my service up to Sunday Last, I have been informed by support the work has been done.  Fault is fixed and as below been closed by BTOW.
Script User - Automated Script Pool
10:50am, Friday 26 Aug 2016
The broadband fault has been closed by the supplier. Should problems re-occur, please restart the Broadband Fault Checker.
Is this the reason I cannot change ISP as they say there is a fault on the line!
1 REPLY 1
Fixes: 290
Re: Is my fault closed or not? Question #131886770
All that message means is that the fault report has been closed on our suppliers systems.
It wouldn't stop you from changing suppliers.
 Matthew Wheeler
