Is my download speed being capped?
northspoon
I have had fibre for about 2 years now, with consistant download speeds of 38Mbps until about 3 months ago. The speed is now around 31Mbps.
I have just renewed my contract for 24 months where the "estimated" speed says it should be 39-40Mbps. I phoned Plusnet support, and one advisor said my line speed was "capped" and opend a support ticket. I was asked to do some tests at my end which told me my line speed was capable of a higher speed.
I am attaching the details of my line speed.
I have had a reply to my ticket, saying that my download speed is within 80% of the estimated speed, and no further action is being carried out.
Should I just accept this explanation, or is there a way to find out if my line is being capped?
Fixes: 58
Re: Is my download speed being capped?
Please post the results of the BT speed test further diagnostics
northspoon
Since my first post, I have again spoken to Plusnet who agree that it needs further checking and are arranging for an BT engineer to check.
Here is the result you asked for:.
Fixes: 58
Which confirms your original assumption - your line is capped - and given your upstream rate you should be getting a lot better
northspoon
I am not very technical.....who might be capping the line and why?
Can I do anything about the situation, apart from waiting for a BT engineer?
Fixes: 58
The automatic system and it needs a BT Engineer to find out why as, not only is it capped, the retransmission is set to high.
All this indicates a line problem somewhere which needs sorting
northspoon
Thank you for the help.
It has taken many calls to PN over the past week to finally agree to do something about this. I had been told my download speed was within the 80% tolerance allowed.
northspoon
One more question, what does the retransmission mean?
Fixes: 58
It means that G.INP is enabled - look that up on Kitz site
northspoon
Called PN again this morning, only to be told the advisor gave me the wrong information yesterday that a BT engineer would be called!!
So back to square one. Seems that PN tell me different things on different days.
UPDATE:  I was called today and the advisor said that an external engineer would look at the issue within 72 hours......because my profile was "banded"......whatever that means?
Fixes: 58
Banded is explained here http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml and is what I was referring to when I agreed it was capped
northspoon
BT engineer called this morning. Fault found on nearby pole. Profile reset...back to 38Mbps  Smiley
carlito
Grettings, how did you get on? i`m experiencing exactly the same problem as you but seems to be capped at 23mb
still awaiting plusnet attention
