Is it possible to stop me/us from being routed through Telia?
FrazUK
Telia has multiple points in their network that suffers from frequent spikes in latency up to 165ms and it ruins online gaming. This has been going on for over 2 years now on both BT Infinity and Plusnet Fiber Extra and it's about time something was done about it.
Here's a couple of the culprits and I'm sure there's more so I'll have a look for them and post them here if there are. Most games I play on EU servers end up with lag spikes/people because latency is constantly bouncing around.
ping 62.115.122.164 -n 100
Pinging 62.115.122.164 with 32 bytes of data:
Reply from 62.115.122.164: bytes=32 time=62ms TTL=55
Reply from 62.115.122.164: bytes=32 time=74ms TTL=55
Reply from 62.115.122.164: bytes=32 time=36ms TTL=55
Reply from 62.115.122.164: bytes=32 time=163ms TTL=55
Reply from 62.115.122.164: bytes=32 time=35ms TTL=55
Reply from 62.115.122.164: bytes=32 time=60ms TTL=55
Reply from 62.115.122.164: bytes=32 time=104ms TTL=55
Reply from 62.115.122.164: bytes=32 time=72ms TTL=55
Reply from 62.115.122.164: bytes=32 time=41ms TTL=55
Reply from 62.115.122.164: bytes=32 time=151ms TTL=55
Reply from 62.115.122.164: bytes=32 time=43ms TTL=55
Reply from 62.115.122.164: bytes=32 time=121ms TTL=55
Reply from 62.115.122.164: bytes=32 time=64ms TTL=55
Reply from 62.115.122.164: bytes=32 time=47ms TTL=55
Reply from 62.115.122.164: bytes=32 time=59ms TTL=55
Reply from 62.115.122.164: bytes=32 time=54ms TTL=55
Reply from 62.115.122.164: bytes=32 time=37ms TTL=55
Reply from 62.115.122.164: bytes=32 time=55ms TTL=55
Reply from 62.115.122.164: bytes=32 time=38ms TTL=55
Reply from 62.115.122.164: bytes=32 time=108ms TTL=55
Reply from 62.115.122.164: bytes=32 time=63ms TTL=55
Reply from 62.115.122.164: bytes=32 time=46ms TTL=55
Reply from 62.115.122.164: bytes=32 time=40ms TTL=55
Reply from 62.115.122.164: bytes=32 time=70ms TTL=55
Reply from 62.115.122.164: bytes=32 time=44ms TTL=55
Reply from 62.115.122.164: bytes=32 time=61ms TTL=55
Reply from 62.115.122.164: bytes=32 time=124ms TTL=55
Reply from 62.115.122.164: bytes=32 time=52ms TTL=55
Reply from 62.115.122.164: bytes=32 time=39ms TTL=55
Reply from 62.115.122.164: bytes=32 time=58ms TTL=55
Reply from 62.115.122.164: bytes=32 time=51ms TTL=55
Reply from 62.115.122.164: bytes=32 time=105ms TTL=55
Reply from 62.115.122.164: bytes=32 time=93ms TTL=55
Reply from 62.115.122.164: bytes=32 time=114ms TTL=55
Reply from 62.115.122.164: bytes=32 time=118ms TTL=55
Reply from 62.115.122.164: bytes=32 time=53ms TTL=55
Reply from 62.115.122.164: bytes=32 time=89ms TTL=55
Reply from 62.115.122.164: bytes=32 time=101ms TTL=55
Ping statistics for 62.115.122.164:
    Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 35ms, Maximum = 163ms, Average = 51ms
ping 62.115.116.252 -n 100
Pinging 62.115.116.252 with 32 bytes of data:
Reply from 62.115.116.252: bytes=32 time=24ms TTL=56
Reply from 62.115.116.252: bytes=32 time=29ms TTL=56
Reply from 62.115.116.252: bytes=32 time=63ms TTL=56
Reply from 62.115.116.252: bytes=32 time=57ms TTL=56
Reply from 62.115.116.252: bytes=32 time=23ms TTL=56
Reply from 62.115.116.252: bytes=32 time=28ms TTL=56
Reply from 62.115.116.252: bytes=32 time=30ms TTL=56
Reply from 62.115.116.252: bytes=32 time=25ms TTL=56
Reply from 62.115.116.252: bytes=32 time=37ms TTL=56
Reply from 62.115.116.252: bytes=32 time=26ms TTL=56
Reply from 62.115.116.252: bytes=32 time=97ms TTL=56
Reply from 62.115.116.252: bytes=32 time=62ms TTL=56
Reply from 62.115.116.252: bytes=32 time=117ms TTL=56
Reply from 62.115.116.252: bytes=32 time=52ms TTL=56
Reply from 62.115.116.252: bytes=32 time=51ms TTL=56
Reply from 62.115.116.252: bytes=32 time=48ms TTL=56
Reply from 62.115.116.252: bytes=32 time=86ms TTL=56
Reply from 62.115.116.252: bytes=32 time=45ms TTL=56
Reply from 62.115.116.252: bytes=32 time=43ms TTL=56
Reply from 62.115.116.252: bytes=32 time=42ms TTL=56
Reply from 62.115.116.252: bytes=32 time=129ms TTL=56
Reply from 62.115.116.252: bytes=32 time=38ms TTL=56
Reply from 62.115.116.252: bytes=32 time=49ms TTL=56
Reply from 62.115.116.252: bytes=32 time=34ms TTL=56
Reply from 62.115.116.252: bytes=32 time=32ms TTL=56
Reply from 62.115.116.252: bytes=32 time=75ms TTL=56
Reply from 62.115.116.252: bytes=32 time=27ms TTL=56
Reply from 62.115.116.252: bytes=32 time=33ms TTL=56
Reply from 62.115.116.252: bytes=32 time=78ms TTL=56
Reply from 62.115.116.252: bytes=32 time=67ms TTL=56
Reply from 62.115.116.252: bytes=32 time=47ms TTL=56
Reply from 62.115.116.252: bytes=32 time=31ms TTL=56
Reply from 62.115.116.252: bytes=32 time=80ms TTL=56
Reply from 62.115.116.252: bytes=32 time=83ms TTL=56
Reply from 62.115.116.252: bytes=32 time=103ms TTL=56
Reply from 62.115.116.252: bytes=32 time=69ms TTL=56
Reply from 62.115.116.252: bytes=32 time=59ms TTL=56
Reply from 62.115.116.252: bytes=32 time=94ms TTL=56
Reply from 62.115.116.252: bytes=32 time=68ms TTL=56
Ping statistics for 62.115.116.252:
    Minimum = 23ms, Maximum = 129ms, Average = 38ms
FrazUK
Re: Is it possible to stop me/us from being routed through Telia?
Here's one I'm routed through when playing CS:GO
ping 80.91.254.4 -n 100
Pinging 80.91.254.4 with 32 bytes of data:
Reply from 80.91.254.4: bytes=32 time=41ms TTL=55
Reply from 80.91.254.4: bytes=32 time=37ms TTL=55
Reply from 80.91.254.4: bytes=32 time=59ms TTL=55
Reply from 80.91.254.4: bytes=32 time=52ms TTL=55
Reply from 80.91.254.4: bytes=32 time=73ms TTL=55
Reply from 80.91.254.4: bytes=32 time=53ms TTL=55
Reply from 80.91.254.4: bytes=32 time=40ms TTL=55
Reply from 80.91.254.4: bytes=32 time=38ms TTL=55
Reply from 80.91.254.4: bytes=32 time=39ms TTL=55
Reply from 80.91.254.4: bytes=32 time=61ms TTL=55
Reply from 80.91.254.4: bytes=32 time=48ms TTL=55
Reply from 80.91.254.4: bytes=32 time=49ms TTL=55
Reply from 80.91.254.4: bytes=32 time=43ms TTL=55
Reply from 80.91.254.4: bytes=32 time=45ms TTL=55
Reply from 80.91.254.4: bytes=32 time=56ms TTL=55
Reply from 80.91.254.4: bytes=32 time=57ms TTL=55
Reply from 80.91.254.4: bytes=32 time=82ms TTL=55
Reply from 80.91.254.4: bytes=32 time=44ms TTL=55
Reply from 80.91.254.4: bytes=32 time=71ms TTL=55
Reply from 80.91.254.4: bytes=32 time=65ms TTL=55
Reply from 80.91.254.4: bytes=32 time=85ms TTL=55
Reply from 80.91.254.4: bytes=32 time=42ms TTL=55
Reply from 80.91.254.4: bytes=32 time=58ms TTL=55
Reply from 80.91.254.4: bytes=32 time=106ms TTL=55
Reply from 80.91.254.4: bytes=32 time=122ms TTL=55
Reply from 80.91.254.4: bytes=32 time=54ms TTL=55
Reply from 80.91.254.4: bytes=32 time=96ms TTL=55
Reply from 80.91.254.4: bytes=32 time=75ms TTL=55
Reply from 80.91.254.4: bytes=32 time=46ms TTL=55
Ping statistics for 80.91.254.4:
    Minimum = 37ms, Maximum = 122ms, Average = 45ms
FrazUK
And another routing to a different CS:GO server (official Valve servers btw)
ping 213.155.137.118 -n 100
Pinging 213.155.137.118 with 32 bytes of data:
Reply from 213.155.137.118: bytes=32 time=25ms TTL=56
Reply from 213.155.137.118: bytes=32 time=24ms TTL=56
Reply from 213.155.137.118: bytes=32 time=48ms TTL=56
Reply from 213.155.137.118: bytes=32 time=28ms TTL=56
Reply from 213.155.137.118: bytes=32 time=100ms TTL=56
Reply from 213.155.137.118: bytes=32 time=23ms TTL=56
Reply from 213.155.137.118: bytes=32 time=38ms TTL=56
Reply from 213.155.137.118: bytes=32 time=29ms TTL=56
Reply from 213.155.137.118: bytes=32 time=86ms TTL=56
Reply from 213.155.137.118: bytes=32 time=77ms TTL=56
Reply from 213.155.137.118: bytes=32 time=45ms TTL=56
Reply from 213.155.137.118: bytes=32 time=64ms TTL=56
Reply from 213.155.137.118: bytes=32 time=98ms TTL=56
Reply from 213.155.137.118: bytes=32 time=67ms TTL=56
Reply from 213.155.137.118: bytes=32 time=95ms TTL=56
Reply from 213.155.137.118: bytes=32 time=85ms TTL=56
Reply from 213.155.137.118: bytes=32 time=58ms TTL=56
Reply from 213.155.137.118: bytes=32 time=114ms TTL=56
Reply from 213.155.137.118: bytes=32 time=30ms TTL=56
Reply from 213.155.137.118: bytes=32 time=55ms TTL=56
Reply from 213.155.137.118: bytes=32 time=31ms TTL=56
Reply from 213.155.137.118: bytes=32 time=84ms TTL=56
Reply from 213.155.137.118: bytes=32 time=26ms TTL=56
Reply from 213.155.137.118: bytes=32 time=75ms TTL=56
Reply from 213.155.137.118: bytes=32 time=103ms TTL=56
Reply from 213.155.137.118: bytes=32 time=40ms TTL=56
Reply from 213.155.137.118: bytes=32 time=69ms TTL=56
Reply from 213.155.137.118: bytes=32 time=71ms TTL=56
Ping statistics for 213.155.137.118:
    Minimum = 23ms, Maximum = 114ms, Average = 35ms
Fixes: 6
If you could post a tracert log, that'll help to see where the problem is.
FrazUK
Thanks for the reply Alex. Here are the traceroutes....
These 2 are CS:GO servers, in the first one, hop 9 is bad and in the second one it's hop 11 but earlier it was hop 10. If you ping those ips youll see the huge variation in latency
tracert 155.133.231.146
Tracing route to 155.133.231.146 over a maximum of 30 hops
  1     1 ms     1 ms     1 ms  LEDE.lan [192.168.1.1]
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4    23 ms    23 ms    23 ms  be3-3100.pcn-ir01.plus.net [195.166.143.128]
  5    24 ms    24 ms    24 ms  core1-BE1.colindale.ukcore.bt.net [195.99.125.132]
  6    24 ms    24 ms    23 ms  peer6-hu0-6-0-2.telehouse.ukcore.bt.net [62.172.103.13]
  7    24 ms    23 ms    25 ms  t2c3-et-3-1-0-0.uk-lon1.eu.bt.net [166.49.211.236]
  8    24 ms    24 ms    24 ms  213.248.82.249
  9    33 ms    89 ms    23 ms  ldn-bb2-link.telia.net [213.155.137.118]
 10    36 ms    36 ms    36 ms  hbg-bb4-link.telia.net [62.115.115.68]
 11    53 ms    53 ms    52 ms  war-b1-link.telia.net [80.91.245.47]
 12    52 ms    53 ms    53 ms  valve-ic-324690-war-b1.c.telia.net [62.115.154.181]
 13     *        *        *     Request timed out.
 14    53 ms    53 ms    53 ms  155.133.231.146
Trace complete.
tracert 155.133.229.156
Tracing route to 155.133.229.156 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  LEDE.lan [192.168.1.1]
  4    23 ms    23 ms    22 ms  be3-3100.pcn-ir01.plus.net [195.166.143.128]
  5    23 ms    23 ms    23 ms  core1-BE1.colindale.ukcore.bt.net [195.99.125.132]
  6    23 ms    23 ms    22 ms  195.99.127.83
  7    24 ms    23 ms    24 ms  t2c3-et-7-3-0-0.uk-lon1.eu.bt.net [166.49.211.230]
  8    22 ms    23 ms    23 ms  213.248.82.249
  9    22 ms    23 ms    23 ms  ldn-bb3-link.telia.net [62.115.138.150]
 10    37 ms    37 ms    37 ms  hbg-bb1-link.telia.net [80.91.254.4]
 11    50 ms    73 ms    78 ms  prag-bb1-link.telia.net [62.115.133.140]
 12    56 ms    56 ms    57 ms  win-b4-link.telia.net [62.115.113.65]
 13    53 ms    53 ms    67 ms  valve-ic-315535-win-b4.c.telia.net [213.248.79.110]
 14     *        *        *     Request timed out.
 15    53 ms    53 ms    53 ms  155.133.229.156
Trace complete.
