Is fibre now available?
scott488
I have recently moved and ordered a fibre connection which was accepted. Just before our move we were then told fibre wasn't available at our new home.
How do I find out when fibre becomes available and do I have to place the order or is it done automatically since that is the service I requested?
SpendLessTime
Aspiring Hero
Fixes: 60
Re: Is fibre now available?
Check here daily entering only your phone number http://www.dslchecker.bt.com/
And when it says it is available, try and order again.
Fixes: 190
As @SpendLessTime the DSL checker is your best bet.
You can also check here to see a more detailed breakdown https://www.homeandwork.openreach.co.uk/when-can-i-get-fibre.aspx
 Matthew Wheeler
