Is everything looking ok expecting more
Adamtemp
From other sites I see ip profile on vdsl is around 96.8 of sync
I am using a bt smart hub 6a below are screen grabs from router etc any comments
GLOBALNET now part of madasafish now plusnet With The same isp since 1995 ( now all part of BT) now on a 21cn exchange wwstal 80/20 fttc
RealAleMadrid
Aspiring Champion
Fixes: 17
Re: Is everything looking ok expecting more
The IP profile can be around 91-92% of sync speed under some conditions, usually reduced SNRM and G.Inp retransmission high. This would explain your profile speed.
Fixes: 538
Hi there. Pretty much what @RealAleMadrid said.
Please let us know if you're having issues with your service.
