Is a DLM reset request possible
helennewby
Hi, I have been away for a few months and  coming home i have found my partner has moved the Internet to a extension socket and the broadband speeds have dropped quite a bit. I have now removed the extension and reconnected the Internet back to the master socket, is there any way you guys can do a reset to get off this ip iprofile.
3 REPLIES 3
helennewby
Re: Is a DLM reset request possible
Line stats
Noise up   17.1     down 22.2
Speed up  1887    down 17196
Att    up   27.9       down    20.7
It used to sync at 37 down and 4 up I think, but certainly much better than it is now
I do use WiFi, but that is not the cause of any of my problems, pc is hardwired if needed
Fixes: 1,529
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
Strat
Fixes: 565
Moderators Note
This topic has been moved from ADSL Broadband to Fibre Broadband.
