Is a DLM reset request possible
- Re: Is a DLM reset request possible
16-09-2020 10:21 AM
Hi, I have been away for a few months and coming home i have found my partner has moved the Internet to a extension socket and the broadband speeds have dropped quite a bit. I have now removed the extension and reconnected the Internet back to the master socket, is there any way you guys can do a reset to get off this ip iprofile.
16-09-2020 10:50 AM
Line stats
Noise up 17.1 down 22.2
Speed up 1887 down 17196
Att up 27.9 down 20.7
It used to sync at 37 down and 4 up I think, but certainly much better than it is now
I do use WiFi, but that is not the cause of any of my problems, pc is hardwired if needed
18-09-2020 2:52 PM
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
20-09-2020 1:02 PM
This topic has been moved from ADSL Broadband to Fibre Broadband.
