Is PN capping my sync speed?
- Re: Is PN capping my sync speed?
12-10-2015 11:35 AM
See my info from PN website and current modem stats. AttainDown=76960 but DataRateDown=60064. Does this mean there is a cap in place?
Estimated line speed:
59Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-10-04 23:59:28
Current line speed:
58.2 Mb
lineState=up
Opmode=ITU G.993.2(VDSL2)
SNRMarginDown=6.1 dB
AttenDown=10.6 dB
SNRMarginUp=6.1 dB
AttenUp=0.1 dB
DataRateDown=60064 kbps
PathModeDown=FastPath
DataRateUp=17054 kbps
PathModeUp=FastPath
WanListMode=1
FECDown=7744
FECUp=1261
CRCDown=1307
CRCUp=228
HECDown=0
HECUp=0
ADSLUpTime=2 days, 12:46, 0 secs
PowerDown=13.3 dbm
PowerUp=6.4 dbm
FarEndVendorID=Infineon(Lantiq)
AttainUp=17183
AttainDown=76960
ShowtimeStart=20
TotalStart=80
Current line speed:
58.2 Mb
lineState=up
AttenDown=10.6 dB
SNRMarginUp=6.1 dB
AttenUp=0.1 dB
PathModeUp=FastPath
WanListMode=1
FECDown=7744
FECUp=1261
CRCDown=1307
CRCUp=228
HECDown=0
HECUp=0
PowerDown=13.3 dbm
PowerUp=6.4 dbm
AttainUp=17183
AttainDown=76960
ShowtimeStart=20
TotalStart=80
Message 1 of 4
(559 Views)
3 REPLIES 3
12-10-2015 11:42 AM
Message 2 of 4
(350 Views)
12-10-2015 11:46 AM
Thanks Matthew I was just curious. Can you offer any thoughts on why the sync is significantly below the max?
dick:quote
dick:quote
Message 3 of 4
(350 Views)
12-10-2015 12:02 PM
Noise margin varies continuously and the attainable is based on the current conditions, i.e. what you might sync at if you resynced at that moment. It suggests that the last resync was at a time when the background noise was higher. Having a good margin as you have at present will give greater stability and fewer errors so unless that small drop in speed is important I'd leave well alone.
Message 4 of 4
(350 Views)
