Irregular internet dropping out
- Irregular internet dropping out
13-10-2020 5:15 PM
Hi
I'm having issues with the internet dropping out, the red light will start flashing for a minute then back to blue and everything fine. But this is happening a few times a week sometimes a few times an evening and looking at all the posts I'm wondering if I made a bad choice with plusnet!!
1 REPLY 1
Re: Irregular internet dropping out
16-10-2020 7:27 AM
There are various causes for broadband connection dropping which may be caused by internal wiring or the infrastructure outside.
Is your router plugged into the master telephone socket? Try using the test socket: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
If there’s still an issue try reporting a fault by going to http://faults.plus.net
This will create a fault ticket and get you into the queue for Plusnet to investigate further.
Message 2 of 2
(115 Views)
