Internet keeps dropping.
- Internet keeps dropping.
11-07-2017 2:46 PM
Over the past 3-4 weeks we've had a few days where the internet will constantly drop out for a minute or two. Sometimes it drops out every few minutes, sometimes it might be okay for an hour before losing connection. Last time was about a week ago but it's happening again today. It affects both wi-fi as well as wired connections.
Any ideas what it might be?
Re: Internet keeps dropping.
11-07-2017 2:59 PM
Listening in with interest; we've had the same problem here.
11-07-2017 3:32 PM
Hi Picklepercy,
I've had a good check of your connection and can see the drops you've explained shown by the graph below:
When testing your connection and line however there isn't anything pointing to what's causing the drops:
Pass | |
Test Outcome Code | GTC_FTTC_SERVICE_0003 |
Description | No problem found, OAM test is not currently supported on this line. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 60.3 Mbps |
Upstream Speed | 15.8 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 635.1 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | Retrains Observed |
Interference Duration Longest Occurrence | From 02:30 to 02:45 |
Interference Location | Unknown |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Retransmission High |
so because our tests aren't picking up exactly where so we will have to do some troubleshooting to start ruling things out.
I'd recommend starting with basic checks here: http://goo.gl/p2tpvL
And if that doesn't help the next thing would be to rule your internal wiring out by plugging the connection into your test socket and seeing if the drops and buffering stop. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
If the problem still persists from here we will go down the route of raising a fault . Let us know how it goes.
Kind regards,
Ben
11-07-2017 3:59 PM
Have just gone through the basic checks and not found anything that would be an issue. I'll check for the master socket tomorrow when I get a chance.
11-07-2017 4:21 PM
Hi Picklepercy, Yeah if you check the test socket then as this will rule out internal wiring and if the drops persist from there get back to us as we will look at raising a fault and getting an engineer out to investigate further.
Kind regards,
Ben
11-07-2017 4:26 PM
Hi @penny-swc ,
Having checked through your connection also I can see your connection has been dropping also:
After checking your connection and line there isn't anything jumping out as to what's causing the drops so I recommend the same steps as above to start ruling things out your side. I'd recommend starting with basic checks here: http://goo.gl/p2tpvL
Kind regards,
Ben
21-07-2017 12:44 PM
After a couple more dropouts this morning I finally got around to plugging into the master socket (as of 12.40pm today). If the connection keeps dropping now, I assume we need to get someone in to have a look at things?
21-07-2017 1:39 PM
And it has dropped out numerous times in the past hour while plugged into the master socket.
21-07-2017 1:54 PM
Could you check mine please too. There is something not right - either my line or wifi and would be good to know which!
21-07-2017 4:57 PM
@picklepercy - When you say you're connected to the master socket, have you removed the faceplate and connected directly to the test socket?
@mcjizja - Your line is testing fine with sync speeds at the maximum your package offers. Do you experience the same speed issues on both a wired and wireless connection?
22-07-2017 8:16 PM
Yes, I have taken off the faceplate and connected to the test socket.
23-07-2017 11:57 AM - edited 23-07-2017 11:58 AM
Mines been bad dropping out every 10-15 mins since thur and often stays down for 5 to 10 mins... shocking service i'm in the test socket with the filter in.
23-07-2017 2:08 PM
Hello (first time here!),
I've been having similar problems over the past 4-5 days. Internet works well but connection drops every 30m or so for 1 minute (more or less). Then it comes back again by itself (without having to reset the router). I've done all the basic checks and can't see anything wrong. Any ideas?
24-07-2017 10:04 AM
It looks like your connection has stabilised over the weekend.
Let us know how it goes over the next few days with the router in the test socket.
Your connection looks pretty unstable.
We'll need to arrange an engineer visit as the next step. I've replied to your fault ticket.
Welcome to the community forums!
Your connection is also dropping quite a bit, to the point where it's likely you'll have no connection at all when the drops are occurring. My tests aren't identifying the cause of that so I'd recommend getting this reported to us at http://faults.plus.net
24-07-2017 10:53 AM
Thanks. Assuming it is all stable and fine now while plugged in the test socket, do I just keep it plugged in there or will I need a new box/face plate?
