Internet just stopped
- Re: Internet just stopped
31-08-2021 9:42 PM
31-08-2021 10:35 PM
Log in to the hub by putting 192.168.1.254 in the address field of your web browser.
On the broadband you should find the username. If it’s setup@pludsls.net then it hasn’t configured itself.
Remove the DSL cable.
Change the username to your account username in the form @plusdsl.net.
Enter your account password.
Plug the DSL cable back in.
31-08-2021 11:14 PM
It’s like it won’t give me an option to change that to my own plusnet username and password. I am baffled why this has happened.
31-08-2021 11:17 PM
Try going to settings> admin password> enter broadband username and password> if it doesn't let you, press disconnect and you should be able to enter in the details
31-08-2021 11:19 PM
Well I have put in my plus net username and password and they are correct so I don’t get what is happening!
31-08-2021 11:21 PM
your username is "yourusername@plusdsl.net"
your password is your own account password
31-08-2021 11:22 PM
It is the correct username as far as I am aware, it’s what I use on the phone to plusnet when I rang about billing a month or so ago. I’m not sure why it’s locking me out.
31-08-2021 11:24 PM
Is this the same username you use to log in online?
Also, ensure the username characters are all lowercase and have no capital letters.
31-08-2021 11:28 PM
‘Internet
You’re already connected to the internet. No further set up is needed.’
But I’m clearly not as it’s not working still!
31-08-2021 11:30 PM
31-08-2021 11:30 PM
If it says "you're already connected" after entering your details,
try opening a new tab and it should be working now
This was same issue with my hub
31-08-2021 11:32 PM
Not sure what happened to be honest. This stuff usually happens when you change your password.
Maybe PN staff can shed light as to why this happened but I've had my fair share of fixing my own Plusnet equipment so happy to share here.
Hope I made your day lol
31-08-2021 11:35 PM
31-08-2021 11:38 PM
Hope you get all your important work done then
Also, mark this post as fixed just so everyone else knows Please
Cheers
